Hi everyone,
Is there any data field, app or widget that displays and records battery discharge data and synchronizes it with Connect?
Thank you very much for your help
Yes, I use a data field called "My EDGE2"
You can assign a whole page to it, but then simply disable that page as the layout isn't to everyones taste . It will still log the battery value through…
You can assign a whole page to it, but then simply disable that page as the layout isn't to everyones taste . It will still log the battery value through your ride and you'll see it as a graph in connect as seen below...
