Heart rate graph in Garmin Connect
Currently the HR graph in Connect is only RED. is it possible to let it change colour as you go into different zones, like the colours used on the "time spend in HR zones" it will be much more use full?
  • I think you may need to check/reset your HR zone on your device or in Garmin connect again. Something must be wrong with those values to show you are in or above your Zone V. It should be coloured.
    I had an issue where my connect settings didn't sync to my Edge device properly and the result was my graphs were always green and yellow. I think it may have gone all weird after I installed a HR data field but I'm not sure.
  • Hi Martin, no its a build issue at Garmin. all the HR graphs are only in one colour...red. they dont identify different zones that you trained in, only the last graph "time spend in HR zones" does that. however i am talking about the heart rate graph...
  • Oh. Oops. Sorry. Thought it was the summary page HR graph.
