Just updated to 4.60 now my phone won't connect, tried through the garmin connect app, I get a passcode shows connected briefly but doesn't finish the pairing and then says 'Pairing Failed'. I using a samsung s7 if that helps. Any ideas??
If you haven't already done so, you can delete any phone pairing on the 830 (if there is one). Uninstall GCM on your phone. Go into your phone's bt settings and remove any 830 pairings there. Reinstall GCM on your phone and then go through the pairing process in GCM.
