V5.00 and ClimbPro?
One thing I noticed is no mention of ClimbPro in changelog whatsoever.
What happened? I'd like to see it for myself, but I have to wait for phased rollout to reach 100% and then some days still Slight smile
  • The changes are there. I document them here.
    https://forums.garmin.com/sports-fitness/cycling/f/edge-830/168010/understanding-climbpro-on-the-edge---updated-for-build-4-19
    Change Log
    Added support for Connect IQ 3.1.
    Added support to control Garmin inReach remotely.
    Made improvements to indoor cycling user experience.
    -- Improved smart trainer discovery and initial setup experience when using an Indoor activity profile.
    -- Improved the Follow Course experience by enabling UI (map, ClimbPro, Elevation, etc) and data recording from the simulated course.
    -- Made improvements to smart trainer sensor calibration.
    Made improvements to Workout user experience.
    -- Added FTP line to workout comparison displays.
    -- Allow graphical workout data fields to be configured on regular data screens.
    -- Improved the display for open steps on the workout comparison graph.
    Made improvements to the ClimbPro user experience.
    -- Made ClimbPro available for navigation to a POI and for round-trip courses.
    -- Added a setting in the ClimbPro data screen setup to specify which climbs should be detected (All, Medium/Large, Large Only).
    -- Removed the ClimbPro page from the timer loop if there are no climbs left in the ride.
    Made improvements to the Segment user experience.
    -- Fixed an issue where segments with slashes in the name would not be processed and would create subfolders on the file system.
    -- Fixed an issue where the segment leader could get reset during a sync.
    -- Added setting in the Segments menu to set a Default Leader Priority, which allows the user to set a default leader to apply to all segments.
    Fixed an issue with pairing to iPhone 11.
    Added pressure filter in order to improve elevation recording.
    Fixed an issue where activities could report inaccurate distances if GPS was acquired after the activity started.
    Improved Firstbeat heat acclimation by utilizing weather forecasts.
    Added ability to render Hebrew text for incoming smart notifications. This requires additional font files. Follow instructions on separate forum post.
    Fixed issues with the map zoom level not being set correctly.
    Fixed an issue where Battery Save Mode could stop working mid-ride.
    Show the jump prompt for each jump in cases where there are multiple jumps in a row.
    Fixed issues with the heart rate graph data field.
    Fixed an issue that caused Auto Detect Max HR to always be enabled.
    Improved the y-scaling on the elevation profile.
    Added directional arrows for round trip courses.
    Fixed cosmetic issues with Extended Display mode.
    Added additional info to the nutrition/hydration settings page
    Turn backlight on when the user laps or there is an autolap during an activity
    Automatically size the text in the elevation data field.
    Improved overall device stability by fixing crashes and freezes.
    0 Former Member in reply to aweatherall
    Well, my bad, dunno how I didn't see it.
    Thanks.
