Edge 830 navigation by Coordinates broken
How to reproduce:
Go to "Navigation" -> "Search" -> "Coordinates"
Input the following coordinates:
N 1.336284
E 103.783644
I can't change the digits at "7".
    Attachin video of the issue
  • The coordinate format used in the posting does not match that used in the video. In the posting it uses hddd.dddddd. In the video hddd mm.mmmm. As such, it is limited from 0-59 on the minutes parts. Typing a 6-9 on that first item fails by design.
    It looks like you need to change the format on the Edge to use the format you posted.
    0 Former Member in reply to aweatherall
    Wow I didn't know I can change the position format on the Edge!
    Solved by changing System -> Units -> Position Format -> hddd.dddddd
