Starting a ride mid couse?
Imagine I create a loop course in Trailforks where the start/stop points are due east. However the course also has access points due south. Can I start navigating this course at the due south access point as long as I answer “No” to “Navigate to start of course?” prompt?
  • Yes.  You can start navigating a course anywhere along it and the unit will give navigation prompts from your location until the end of the course.  In your situation if you wanted to have navigation back to where you started the course you would need to restart the navigation when you reached the programmed start point.
  • Hi, can you explain how that works? The exact situation has happened to me several times and I only have the option to "navigate to start" as opposed to continuing the course. Thank you
  • Select no.
    The course will calculate.
    Start riding along the course from where you are
    All of the Garmins work this way.
    All the way back to the 800.
