Several bugs
Is anyone else having the following bugs?
  • sometimes when turning off my Edge, it remains stuck at the power-off screen. I then need to soft reset my device when this happens, else I'm not able to power it on again
  • battery drains while off and sometimes I have some battery drop of several % (like 30%) in a few minutes while doing nothing extraordinary (changing setting or just „browsing„). Also mentioned in the Edge 530 Forum
  • mtb trails won‘t work. Also mentioned in the Edge 530 Forum
  • For the battery drain issue - could you please check if any CIQ stuff could cause this? If there is one thing that is significantly better on the 530/830 is battery. ;-)
  • Stuck at power off screen:
    I 've noticed that too, but only when powering it off just after powering it up.
    "Just after" here means having main screen ready but 'receiving' notification in top bar still on.
    0 Former Member over 5 years ago
    Regarding the battery drain, are you sure you aren't putting it into sleep mode?  A quick press of the power goes to sleep, where a long press fully powers off.  I ran into this on my first Edge because I didn't know.
    • Yep, I'm properly turning my Edge off, no sleep mode (long press power button and choose turn off)
    • I've already deleted an IQ-Datafiel which I suspect could have been the source of the massive battery drop. So far no drops yet, but it still has the slow battery drain while off
    • Re stuck screen: I'm having this problem regardless of how long the Edge has been powered on
    But thx so far Grinning
