Turn guidance does not work when on a course. It works if navigating to the start of a course and it works if I go off course but when on course the top of the map screen that should show distance to next etc is blank and if I tap that area the cue sheet simply lists very short distances in meters but nothing else. I have Turn Guidance enabled and selected Prompt to Recalculate. Course Points enabled or disabled makes no difference.
On Course screen shots:
Off Course or navigate to start screen shots:
Once the first ClimbPro profile pops up it is repeatedly rapidly replaced with meaningless guidance prompts that probably reflect the rubbish cue sheet entries.
Changing from 3.50 to 3.55 beta did not help and I have reset the device several times from the settings menu.
The courses have been created on Strava or down loaded from ridewithgps, installed onto the 830 as GPX, TXC or FIT files via New Files but none work. Loaded courses from Strava Routes do not work nor do imports from RWGPS using routeCourse app from the IQ store which converts to FIT files for installation. These files work perfectly on my old edge 800 and work perfectly on friends’ 1030 devices.
any ideas??
