I copied some files from 820. Activities and Records worked but Totals didn't work.
AlexKeaton - can you attach the Totals file from the 820 and the 830 in a reply and I will what I can do.
cheers
Mike
Thank you for the response. I think it wasn't transferred because I renamed activity profile on 820. I renamed them to match to those on 830 and made a few activities to make sure totals file was updated. Then, copied the file to 830. However, only totals of new activities were transferred. 820 shows totals from the beginning tho.
I gave up and already recorded a serious activity on 830..
AlexKeaton - what you are trying to do is still achievable. If you attach the Totals.fit file from the Totals folder of both devices then I can combine the totals. Very easily done.
I just did it last night for a lady who has gone to a Fenix from a 235.
cheers
Mike
Hi
which .fit editor do you use?
thanks
Artem
Hello AlexKeaton, I tried to send you a message directly, but it is impossible, so I am writing here hoping you will read it and answer me. I just moved from 820 to 830 and my totals on the new device are showin 0 :( while on my 820 i had 14k+ ridden. Can you help me somewhow? TYVM
Can you zip the totals.fit file from your 820 and 830 and insert into your post?
+Totals.ziphere it is :)
I don't have an Edge device so can't really test it. Basically just matched what you had on the 820 and put it into the FIT file for the 830 using Fit File Repair Tool.
TYVM! Can you also edit my records.fit? I need to add fastest 40km at 1:18:07 from 4.APR.2017 and longest distance at 228km from 12.JUN.2020, TYVM again!
Records can be send via Garmin Connect. Don’t know if it is possible via app, but via Web for shure
