Strava routes and segments
As we know the only solution to concurrently follow a course and ride segments is through Strava Routes app. On Segment page I`ve always had Dist to go. on the segment and Time Ahead/Behind field. As for the first field currently it is not showing distance to the end of segment but distance to the end of course. Does anyone know how to make it right - maybe there is different field ? If not following a course on Strava Routes - Dist to go is working fine. As for the second field I can`t find Time Ahead/Behind field on 830 only Time Ahead or Time Behind. This combined field was present in Edge 820 and was working fine. Moreover Time ahead is giving me similar behaviour as Dist to go i.e. is taking time for total course not segments. Currently I`ve changed the layout to have the graph instead of field so maybe this will work. Again if anyone knows how to make it right I would appreciate. Otherwise maybe there need some fixing in firmware/Strava app
