Garmin restarts after update to 3.50
I tried to update my Garmin to 3.50 over the air and after that it begins restarts again and again. I connected it to the Mac in a drive mode, sync it via Garmin Express. But unfortunately nothing helps, my device continue to restart. Is there any way to solve this problem? I guess this is a software, may be I need to downgrade to 3.20 version.
  • Check the contents of the Garmin\NewFiles folder. It maybe having trouble processing a file in that folder.
    Move anything in that folder to your PC and then see if it starts.
  • I cleaned it, disconnect from PC, the problem stays.
  • There is a err_log.txt content, hope this helps
    "unit_id":"3998092384",
    "product_name":"Edge 830",
    "software_part_number":"006-B3122-00",
    "ms_since_epoch":1562091986000,
    "system_version":"3.50",
    "build_type":"PRODUCTION",
    "backtrace":"
    Function Address: 0x603727E8
    Call Address at Function: 0x60373120
    Function Address: 0x6044B2FC
    Call Address at Function: 0x6044B392
    Function Address: 0x601A17D4
    Call Address at Function: 0x601A1802
    Function Address: 0x601A1974
    Call Address at Function: 0x601A1988
    Function Address: 0x601A1FB4
    Call Address at Function: 0x601A1FE6
    Function Address: 0x60401BDC
    Call Address at Function: 0x60401BF4
    Function Address: 0x603FFCA4
    Call Address at Function: 0x603FFDC6
    Function Address: 0x604010FC
    Call Address at Function: 0x60401158
    Function Address: 0x6038571C
    Call Address at Function: 0x603857CA
    Function Address: 0x6038599C
    Call Address at Function: 0x60385B4A
    Function Address: 0x607255C8
    Call Address at Function: 0x607255FE
    "error_cause":"RTL Trap",
    "proprietary_info":{
    "Commit ID":"4da280b326ad9621b5b6f28ae07c39527fbc3c8a",
    "Time":"2019-7-2 12:26:26",
    "Project Specific":"2019-7-2 12:26:26",
    "CDP_LOG":"605A75CD,",
    "RTL Error Number":"6E5D8027",
    "Error Message":"00000000,D04A3248,D04A13B4,00002EF0,D04A13B0,00000020,00000000,61FFE040,D04A323C,04C11DB7,0000000C,00000000,D04A325C,6225C590,60373113,60373120,6000003F",
    "Task Name":"load_maps_Spawn",
    "Saved SP":"6225C590",
    "Saved LR":"60373113",
    "Saved PC":"60373120",
    "R[0]":"00000000",
    "R[1]":"D04A3248",
    "R[2]":"D04A13B4",
    "R[3]":"00002EF0",
    "R[4]":"D04A13B0",
    "R[5]":"00000020",
    "R[6]":"00000000",
    "R[7]":"61FFE040",
    "R[8]":"D04A323C",
    "R[9]":"04C11DB7",
    "R[10]":"0000000C",
    "R[11]":"00000000",
    "R[12]":"D04A325C",
    "R[13]":"6225C590",
    "R[14]":"60373113",
    "R[15]":"60373120",
    "cpsr":"6000003F"
