Hello, I have problems with the radar RTL 511. It works the radar or the light. Both together cannot be coupled. Does anyone else have this problem?
The best way to pair the RTL as both a radar and a light is as follow.
Delete the current radar or light pairing from the Edge.
Next put the RTL in pairing mode. With the RTL off hold the power button down until the LED flashes purple. Then add it to the Edge as a light. It should then also add it as radar as well as part of adding it as a light
I have already tried this. I called the support earlier. This is a known issue.
Are you selecting both from the search or just the light?
I search only the light and add this. Then he automatically adds the radar sensor.
