Location in weather widget stuck
Hi!
I don't find a solution to let the weather widget show any other location than that of the first start of the edge.
I bought mine in a bike shop and set it up in the train back home.
Im using Connect on iOS, location services are enabled and allowed.
In Connect, I tried to disable and reenable the weather service. I did the same with the weather widget. No matter what I do, it is always showing the location where I first "used" the edge.
  • I have the same issue... but in my case with Android. With all permissions enabled in my Samsung Galaxy S8 for the App connect... And the location of the weather widget keeps stuck. I've try with a full reset, but appears again, the same location... Please Garmin... Fix this issue...
  • The data location doesn’t change because you don’t travel far enough. The stations are pretty far away from each other. In my case, it changes when I drive to work 50km north. This means 80kms between the two weather stations in the middle of Germany. We have usually 3-4°C Difference between these stations and I’m not yet talking about rain and other weather details.
    on other places in connect, there is another weather source sich is much finer. GArmin should check their partners and licenses to supply consistent and good weather data Toni’s customers.
