Trailforks maps on Europe device
Hi, I've bought Edge 830 from UK store, and when I connected it via Garmin Express, it shows there is Trailforks US/Canada 2018 map only. Is this ok?
  • Hm, is it corrected for 530 only?
    On my 830 it's still UK/Canada (even it doesn't matter as I read from 530 forum)
  • There is something wrong here. GE should be offering an update to the Trailforks map to a 2019 build as well as either offering an update to the European maps or an option to re-install.
    Could you post the GarminDevice.xml file from the Garmin folder on your unit.
  • GarminDevice.xml
    <?xml version="1.0" encoding="UTF-8"?><Device xmlns="http://www.garmin.com/xmlschemas/GarminDevice/v2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.garmin.com/xmlschemas/GarminDevice/v2 http://www.garmin.com/xmlschemas/GarminDevicev2.xsd http://www.garmin.com/xmlschemas/GarminDeviceExtensions/DataTypeLocation/v1 http://www.garmin.com/xmlschemas/DataTypeLocationExtension1.xsd" xmlns:dtlx="http://www.garmin.com/xmlschemas/GarminDeviceExtensions/DataTypeLocation/v1"><Model><PartNumber>006-B3122-00</PartNumber><SoftwareVersion>320</SoftwareVersion><Description>Edge 830</Description></Model><Id>3997231484</Id><Unlock><Code>XLLY48WW7EF8NFGMW9QRWRKDA</Code></Unlock><Unlock><Code>PXA99LGXZ9CE6GP3G4CZMMQUJ</Code></Unlock><MassStorageMode><DataType><Name>CustomMaps</Name><File><Specification><Identifier>http://www.opengis.net/kml/2.2</Identifier><Documentation>http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd</Documentation></Specification><Location><Path>Garmin/CustomMaps</Path><FileExtension>KMZ</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>BirdsEye</Name><File><Specification><Identifier>JNX</Identifier></Specification><Location><Path>Garmin/BirdsEye</Path><FileExtension>JNX</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File><File><Specification><Identifier>JNX 4</Identifier></Specification><Location><Path>Garmin/BirdsEye</Path><FileExtension>JNX</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>FITBinary</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin</Path><BaseName>Device</BaseName><FileExtension>FIT</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_2</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Settings</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_3</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Sports</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_4</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Activities</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_5</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Workouts</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_6</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Courses</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_7</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Schedules</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_8</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Locations</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_9</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Weight</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_10</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Totals</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_29</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Records</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_34</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Segments</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_35</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Segment_List</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_40</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/HMD</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_44</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Metrics</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_41</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/ChngLog</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FIT_TYPE_20</Name><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/Summary</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>FIT</Identifier></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>FIT</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FitnessCourses</Name><File><Specification><Identifier>http://www.garmin.com/xmlschemas/TrainingCenterDatabase/v2</Identifier><Documentation>http://www.garmin.com/xmlschemas/TrainingCenterDatabasev2.xsd</Documentation></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>TCX</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>FitnessWorkouts</Name><File><Specification><Identifier>http://www.garmin.com/xmlschemas/TrainingCenterDatabase/v2</Identifier><Documentation>http://www.garmin.com/xmlschemas/TrainingCenterDatabasev2.xsd</Documentation></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>TCX</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>GPSData</Name><File><Specification><Identifier>http://www.topografix.com/GPX/1/1</Identifier><Documentation>http://www.topografix.com/GPX/1/1/gpx.xsd</Documentation></Specification><Location><Path>Garmin/NewFiles</Path><FileExtension>GPX</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>NMaps</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>TrailForks</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>PreProgrammedMaps2</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmapprom2</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>BaseMaps</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmapbmap</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>PreProgrammedMaps</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmapprom</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>PreProgrammedMaps1</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmapprom1</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>SupplementalMaps</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmapsupp</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>PreProgrammedDEMMaps</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmapdem</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>NamedTrails</Name><File><Specification><Identifier>NTRL</Identifier></Specification><Location><Path>Garmin/SQL</Path><FileExtension>db</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>PreProgrammedGeocodeMaps</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmapgc</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>TimeZoneMaps</Name><File><Specification><Identifier>IMG</Identifier></Specification><Location><Path>Garmin</Path><BaseName>gmaptz</BaseName><FileExtension>img</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>TranslatedText</Name><File><Specification><Identifier>http://www.garmin.com/xmlschemas/GarminTextTranslation/v1</Identifier><Documentation>http://www.garmin.com/xmlschemas/GarminTextTranslationv1.xsd</Documentation></Specification><Location><Path>Garmin/Text</Path><FileExtension>gtt</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>FTLImageVersion</Name><File><Specification><Identifier>VER</Identifier></Specification><Location><Path>Garmin</Path><BaseName>fs_image</BaseName><FileExtension>ver</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>CustomPOI</Name><File><Specification><Identifier>GPI0.0</Identifier></Specification><Location><Path>Garmin/POI</Path><FileExtension>gpi</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>Safety_Cameras_PROM_Provider_1</Name><File><Specification><Identifier>GPI</Identifier></Specification><Location><Path>Garmin/POI</Path><FileExtension>GPI</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>EphemerisSony</Name><File><Specification><Identifier>DAYS_3</Identifier></Specification><Location><Path>/Garmin/RemoteSW/</Path><BaseName>CPE</BaseName><FileExtension>BIN</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>WiFiConfiguration</Name><File><Specification><Identifier>WIFI</Identifier></Specification><Location><Path>Garmin/WIFI</Path><BaseName>OUT</BaseName><FileExtension>BIN</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>WIFI</Identifier></Specification><Location><Path>Garmin/WIFI</Path><BaseName>IN</BaseName><FileExtension>BIN</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>ErrorShutdownReports</Name><File><Specification><Identifier>ERR_RPT</Identifier></Specification><Location><Path>Garmin/Debugging</Path><BaseName>err_log</BaseName><FileExtension>txt</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File></DataType><DataType><Name>IQDataFields</Name><File><Specification><Identifier>PRG</Identifier></Specification><Location><Path>GARMIN/APPS</Path><FileExtension>PRG</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>IQWatchApps</Name><File><Specification><Identifier>PRG</Identifier></Specification><Location><Path>GARMIN/APPS</Path><FileExtension>PRG</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>IQWidgets</Name><File><Specification><Identifier>PRG</Identifier></Specification><Location><Path>GARMIN/APPS</Path><FileExtension>PRG</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>IQAppsConfiguration</Name><File><Specification><Identifier>IQAppsConfiguration</Identifier></Specification><Location><Path>GARMIN/APPS</Path><BaseName>OUT</BaseName><FileExtension>BIN</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File><File><Specification><Identifier>IQAppsConfiguration</Identifier></Specification><Location><Path>GARMIN/APPS</Path><BaseName>IN</BaseName><FileExtension>BIN</FileExtension></Location><TransferDirection>InputToUnit</TransferDirection></File></DataType><DataType><Name>IQAppsSettingsFile</Name><File><Specification><Identifier>SET</Identifier></Specification><Location><Path>GARMIN/APPS/SETTINGS</Path><FileExtension>SET</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>IQAppsObjectStoreFile</Name><File><Specification><Identifier>STR</Identifier></Specification><Location><Path>GARMIN/APPS/DATA</Path><FileExtension>STR</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>IQAppsMailboxFile</Name><File><Specification><Identifier>MBX</Identifier></Specification><Location><Path>GARMIN/APPS/MAIL</Path><FileExtension>MBX</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><DataType><Name>IQErrorReports</Name><File><Specification><Identifier>YML</Identifier></Specification><Location><Path>GARMIN/APPS/LOGS</Path><BaseName>CIQ_LOG</BaseName><FileExtension>YML</FileExtension></Location><TransferDirection>OutputFromUnit</TransferDirection></File></DataType><DataType><Name>MountainMapTheme</Name><File><Specification><Identifier>KMTF</Identifier></Specification><Location><Path>GARMIN/MAPTHEMES</Path><BaseName>mountain</BaseName><FileExtension>KMTF</FileExtension></Location><TransferDirection>InputOutput</TransferDirection></File></DataType><UpdateFile><PartNumber>006-D7621-00</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Danish.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-01</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Dutch.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-02</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Finnish.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-03</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>French.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-04</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>German.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-05</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Italian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-06</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Norwegian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-08</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Spanish.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-09</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Swedish.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-10</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Croatian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-11</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Czech.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-12</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Hungarian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-13</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Polish.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-14</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Slovakian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-15</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Slovenian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-16</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Russian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-17</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Greek.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-D7621-18</PartNumber><Version><Major>1</Major><Minor>20</Minor></Version><Path>Garmin/Text</Path><FileName>Brazilian.gtt</FileName></UpdateFile><UpdateFile><PartNumber>006-F0060-10</PartNumber><Version><Major>3</Major><Minor>0</Minor></Version><Path>Garmin</Path><FileName>gmapbmap.img</FileName></UpdateFile><UpdateFile><PartNumber>006-D6016-01</PartNumber><Version><Major>18</Major><Minor>20</Minor></Version><Path>Garmin</Path><FileName>gmapprom.img</FileName></UpdateFile><UpdateFile><PartNumber>006-D6017-01</PartNumber><Version><Major>18</Major><Minor>20</Minor></Version><Path>Garmin</Path><FileName>gmapprom1.img</FileName></UpdateFile><UpdateFile><PartNumber>006-D7557-01</PartNumber><Version><Major>18</Major><Minor>20</Minor></Version><Path>Garmin</Path><FileName>gmapprom2.img</FileName></UpdateFile><UpdateFile><PartNumber>006-D1074-00</PartNumber><Version><Major>22</Major><Minor>0</Minor></Version><Path>Garmin</Path><FileName>gmaptz.img</FileName></UpdateFile><UpdateFile><PartNumber>006-D4728-10</PartNumber><Version><Major>18</Major><Minor>20</Minor></Version><Path>Garmin</Path><FileName>gmapgc.img</FileName></UpdateFile><UpdateFile><PartNumber>006-D4713-06</PartNumber><Version><Major>17</Major><Minor>20</Minor></Version><Path>Garmin</Path><FileName>gmapdem.img</FileName></UpdateFile><UpdateFile><PartNumber>006-D7557-01</PartNumber><Version><Major>18</Major><Minor>20</Minor></Version><Path>Garmin</Path><FileName>gmapprom2.img</FileName></UpdateFile><UpdateFile><PartNumber>006-B3122-00</PartNumber><Version><Major>3</Major><Minor>20</Minor></Version><Path>Garmin</Path><FileName>GUPDATE.GCD</FileName></UpdateFile><UpdateFile><PartNumber>006-B3107-00</PartNumber><Version><Major>2</Major><Minor>30</Minor></Version><Path>Garmin/RemoteSW</Path><FileName>006B310700.GCD</FileName></UpdateFile><UpdateFile><PartNumber>006-B3157-00</PartNumber><Version><Major>0</Major><Minor>24</Minor></Version><Path>Garmin/RemoteSW</Path><FileName>006B315700.GCD</FileName></UpdateFile></MassStorageMode><Extensions><CustomMapsExtension xmlns="http://www.garmin.com/xmlschemas/GarminDeviceExtensions/CustomMaps/v1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.garmin.com/xmlschemas/GarminDeviceExtensions/CustomMaps/v1 http://www.garmin.com/xmlschemas/CustomMapsExtension.xsd"><MaxImageFileSize>3145728</MaxImageFileSize><MaxImages>100</MaxImages><MaxImageResolution>1048576</MaxImageResolution><AllowedFileType>jpg</AllowedFileType><Extensions></Extensions></CustomMapsExtension><DeviceExtension xmlns="http://www.garmin.com/xmlschemas/GarminDeviceExtensions/v1" xsi:schemaLocation="http://www.garmin.com/xmlschemas/GarminDeviceExtensions/v1 http://www.garmin.com/xmlschemas/GarminDeviceExtensionv1.xsd"><Ifix>927403416</Ifix></DeviceExtension><IQAppExt xmlns="http://www.garmin.com/xmlschemas/IqExt/v1"><MaxApps>16</MaxApps><AppSpace>8388608</AppSpace><Preloads><App><StoreId>945c964a-314b-41fa-9a13-32a1f7931335</StoreId><Version>16</Version></App><App><StoreId>bb90841e-a0ea-49a3-b6a8-457ae85738b3</StoreId><Version>18</Version></App><App><StoreId>26b07fba-ae21-43c9-a88d-6c75e17fc567</StoreId><Version>8</Version></App></Preloads><Apps><App><AppName>Strava Routes</AppName><StoreId>945c964a-314b-41fa-9a13-32a1f7931335</StoreId><AppId>02cd6952-e76f-4806-899e-0d89d56f0018</AppId><AppType>watch-app</AppType><Version>16</Version><FileName>A07DC8C.PRG</FileName></App><App><AppName>Best Bike Split</AppName><StoreId>bb90841e-a0ea-49a3-b6a8-457ae85738b3</StoreId><AppId>fdfcc57a-7cec-4d66-8423-678a8f54f3bb</AppId><AppType>watch-app</AppType><Version>18</Version><FileName>E81BEE7.PRG</FileName></App><App><AppName>Trailforks</AppName><StoreId>26b07fba-ae21-43c9-a88d-6c75e17fc567</StoreId><AppId>1e538654-b58d-45bb-a38c-ec198c2745b8</AppId><AppType>watch-app</AppType><Version>8</Version><FileName>EE6F0A5.PRG</FileName></App></Apps><StoreKey><Modulus>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</Modulus><Exponent>65537</Exponent></StoreKey><VmVersion>3.0.8</VmVersion></IQAppExt></Extensions></Device>
    Trailfork is unlocked, I can browse e.g. my region (Germany). There is an option to re-install but it gives the same version of 2018
  • I logged off from CIQ app and on re-login I can authorize by GCM but device shows message "No route data". Same when I select unlock map.
  • Hi,
    For me it behaves the very same - name of the map indicates US/Canada, the whole world seems to be covered tho. No update offered.
    Cheers
    Marek
