Display quality ... ?
Do you think the 830 will have a better touch screen compared to 820? Without "screen halo"
  • Touch maybe better. Just wait - I would not recomment to be early adaptor.
    Screen resolution seems not to get improvement - embarassing.
  • The screen touch response is incredibly improved over the 820. It's just like the 1030.
  • I have zero experience with 820. But if the 830 screen is significant improvement I cannot imagine how 820 worked. For me 830 is far from good. I opted for 830 because of additional navigation features. And while I use Di2 to control the head unit I do not need to work with the touch screen while riding I am accepting it, but as I said - I do not rate it positive.
  • Hm, I was about to choose the 830 over the 530, because of the good touchscreen reviews.
    Now I am not sure anymore. What issues do you have with the touchscreen?
  • Same here. Nonetheles DCR was very positive about it and said he did not hear about so negative experience. But I have to admit that it my first touch-screen Garmin so my expectations my be "incorrect". I chose 830 to have better navigation (530 does not have "go to address").
  • Hm, so I still have no clue, how usable it would be in practice. :D If you could live without the additional Navigation features, would you buy a device with touchscreen again? :)
  • No. The possibility to navigate to address or POI was the only reason for me. I used 520 as last Garmin and moved over to Bolt. Now I believed I could go back to Garmin (I have also FR935 anyway). Mydecision to opt for 830 was mainly drive by super positive reviews for 830 and negative ones for Wahoo Roam.....
    0 Former Member over 5 years ago
    If it's like 1030, then it's kind of "good".
    It will not be as smooth as a smart phone if the processing power and the OS is not going to be power efficient enough to have 20 working hrs.
    I think one could consider the review "misleading" to many general consumers. However, to those from previous versions of touch 810, 820 and 1000, the 1030/830 touch responsiveness is "good". At least now it calculates reroute in navigation much faster, and you start a course with navigation much faster than before...
  • The comparison with smartphones is often partial and misleading, because these are two completely different class of products with unrelated use case. eg. try using your smartphone touch screen with winter cycling gloves on and you'll realize how much better the garmin edge screen is. Or try using your smartphone with sweat drops or rain on it, it becomes totally useless.
  • I haven’t found there to be a ‘halo’ effect when I use it. Didn’t have the 820 to compare though. The screen is very sensitive so you don’t need to push it hard enough to get a halo.
