Edge 540 - set odometer
Hi all,
My old Garmin Edge 530 fell apart and I have a new Edge 540. I tried to update the odometer to the value I had on my Edge 530 by following the fit to csv approach, but unfortunately this didn't work. My csv file contains of only one line without numbers.
Is there someone in the community that could help me with setting the odometer in my new Garmin Edge 540?
Thanks in advance!
  • Yes, there is way using the site gotoes.org. There you can edit your totals.fit file with your desired numbers. Just use the "FIT File View and Repair Tool". I was in the same situation and after a long search I found this wonderful site.
