Is Trail Forks Connect IQ App crashing my Edge 540?
Edge 540 FW 28.20
I experienced an issue last Friday where my device crashed and restarted 8 times in a 2.5 hr training. It would dump logs then reboot. I could not pinpoint what was causing the crash.
Troubleshooting eventually lead me to factory reset it, and it worked perfectly for  the next 3 rides/ 10 hrs of use.
I added the trailforks app back in yesterday and the device just crashed and rebooted 4 seconds into an activity. I removed the trailforks app from the device to test.
Here is the log: Can anyone find any clues in this, or have you experienced frequent crashing since updating to 28.20?
File Name: 0:/Garmin/Debug/EventLogs//00000014.TXT
>>>>> EVL_CURR_LOGS <<<<<
verNum: 8/13/2014 (00)
ownerID: 00000002
OwnerName: HWM
status: 01
pri_thresh: 2
archived: 00
max_arch: 00
num_recs: 80
rec_size: 40
next_evnt: 48
timeDay: 2025/ 9/ 2 19:46:43
cycle_cnt: 329
48: D3 10 00 00 0:00:14.432 HWM_blue (Loc:2025/ 8/29 15:02:45 ) (UTC:2025/ 8/29 19:02:45 ) F:0
49: D3 10 00 00 0:00:23.922 HWM_wifi (Loc:2025/ 8/29 15:02:54 ) (UTC:2025/ 8/29 19:02:54 ) F:0
4A: FE 01 02 00 0:07:05.653 SYC main 2025/ 8/29 19:09:36 V:4191
4B: FF 00 00 00 0:00:00.823 SYC main 2025/ 8/29 19:09:36 C:302
4C: D3 10 00 00 0:01:15.335 HWM_blue (Loc:2025/ 8/29 15:10:51 ) (UTC:2025/ 8/29 19:10:51 ) F:0
4D: D7 10 00 00 0:05:37.696 HWM_main Cable Type Connected: None (None)
4E: D7 10 00 00 0:05:37.961 HWM_main Cable Type Connected: Standard (500mA)
4F: FE 01 02 00 0:05:50.453 SYC main 2025/ 8/29 19:15:27 V:4268
50: FF 00 00 00 0:00:00.815 SYC main 2025/ 8/29 19:15:27 C:303
51: D7 10 00 00 0:00:00.864 HWM_usb_ Cable Type Connected: None (None)
52: D7 10 00 00 0:00:01.268 HWM_main Cable Type Connected: None (500mA)
53: FE 01 02 00 0:03:42.526 SYC main 2025/ 8/29 19:19:09 V:4294
54: FF 00 00 00 0:00:00.787 SYC main 2025/ 8/29 19:19:10 C:304
55: D7 10 00 00 0:00:02.168 HWM_main Cable Type Connected: None (None)
56: D7 10 00 00 0:00:02.413 HWM_main Cable Type Connected: Standard (500mA)
57: D3 10 00 00 0:00:31.306 HWM_blue (Loc:2025/ 8/29 15:19:41 ) (UTC:2025/ 8/29 19:19:41 ) F:0
58: D3 10 00 00 0:00:41.973 HWM_wifi (Loc:2025/ 8/29 15:19:52 ) (UTC:2025/ 8/29 19:19:52 ) F:0
59: FE 01 02 00 0:00:55.137 SYC main 2025/ 8/29 19:20:05 V:4322
5A: FF 00 00 00 0:00:00.800 SYC main 2025/ 8/29 19:20:04 C:305
5B: D7 10 00 00 0:00:00.849 HWM_usb_ Cable Type Connected: None (None)
5C: D7 10 00 00 0:00:01.253 HWM_main Cable Type Connected: None (500mA)
5D: FE 01 02 00 0:02:02.986 SYC main 2025/ 8/29 19:22:07 V:4315
5E: FF 00 00 00 0:00:00.786 SYC main 2025/ 8/29 19:22:08 C:306
5F: D3 10 00 00 0:00:12.217 HWM_blue (Loc:2025/ 8/29 15:22:19 ) (UTC:2025/ 8/29 19:22:19 ) F:0
60: D3 10 00 00 0:00:32.911 HWM_wifi (Loc:2025/ 8/29 15:22:41 ) (UTC:2025/ 8/29 19:22:41 ) F:0
61: D3 10 00 00 0:02:00.402 HWM_wifi (Loc:2025/ 8/29 15:24:08 ) (UTC:2025/ 8/29 19:24:08 ) F:0
62: D3 10 00 00 0:06:46.996 HWM_blue (Loc:2025/ 8/29 15:28:55 ) (UTC:2025/ 8/29 19:28:55 ) F:0
63: FE 01 02 00 0:08:31.881 SYC main 2025/ 8/29 19:30:40 V:4208
64: FF 00 00 00 0:00:00.781 SYC main 2025/ 8/29 19:31:06 C:307
65: D3 10 00 00 0:00:14.842 HWM_blue (Loc:2025/ 8/29 15:31:20 ) (UTC:2025/ 8/29 19:31:20 ) F:0
66: D3 10 00 00 0:00:21.293 HWM_wifi (Loc:2025/ 8/29 15:31:28 ) (UTC:2025/ 8/29 19:31:28 ) F:0
67: D7 10 00 00 0:08:38.226 HWM_main Cable Type Connected: None (None)
68: D7 10 00 00 0:08:38.470 HWM_main Cable Type Connected: Standard (500mA)
69: FE 01 02 00 0:08:49.634 SYC main 2025/ 8/29 19:39:56 V:4327
6A: FF 00 00 00 0:00:00.795 SYC main 2025/ 8/29 19:39:56 C:308
6B: D7 10 00 00 0:00:00.880 HWM_usb_ Cable Type Connected: None (None)
6C: D7 10 00 00 0:00:01.248 HWM_main Cable Type Connected: None (500mA)
6D: FE 01 02 00 0:42:02.357 SYC main 2025/ 8/29 20:21:58 V:4349
6E: FF 00 00 00 0:00:00.784 SYC main 2025/ 8/30 11:22:11 C:309
6F: D7 10 00 00 0:00:01.029 HWM_main Cable Type Connected: None (None)
70: D7 10 00 00 0:00:01.229 HWM_main Cable Type Connected: Standard (500mA)
71: D3 10 00 00 0:00:13.284 HWM_blue (Loc:2025/ 8/30 7:22:24 ) (UTC:2025/ 8/30 11:22:24 ) F:0
72: FE 01 02 00 0:00:33.868 SYC main 2025/ 8/30 11:22:44 V:4349
73: FF 00 00 00 0:00:00.797 SYC main 2025/ 8/30 11:22:45 C:310
74: D7 10 00 00 0:00:00.846 HWM_usb_ Cable Type Connected: None (None)
75: D7 10 00 00 0:00:01.249 HWM_main Cable Type Connected: None (500mA)
76: FE 01 02 00 0:04:39.481 SYC main 2025/ 8/30 11:27:24 V:4344
77: FF 00 00 00 0:00:00.798 SYC main 2025/ 8/30 11:27:25 C:311
78: D3 10 00 00 0:00:12.582 HWM_blue (Loc:2025/ 8/30 7:27:37 ) (UTC:2025/ 8/30 11:27:37 ) F:0
79: D7 10 00 00 0:00:52.650 HWM_main Cable Type Connected: None (None)
7A: D7 10 00 00 0:00:52.897 HWM_main Cable Type Connected: Standard (500mA)
7B: FE 01 02 00 0:01:05.261 SYC main 2025/ 8/30 11:28:30 V:4349
7C: FF 00 00 00 0:00:00.786 SYC main 2025/ 8/30 11:28:30 C:312
7D: D7 10 00 00 0:00:00.835 HWM_usb_ Cable Type Connected: None (None)
7E: D7 10 00 00 0:00:01.239 HWM_main Cable Type Connected: None (500mA)
7F: FE 01 02 00 0:01:56.763 SYC main 2025/ 8/30 11:30:26 V:4349
00: FF 00 00 00 0:00:00.793 SYC main 2025/ 8/30 11:30:27 C:313
01: D3 10 00 00 0:00:12.104 HWM_blue (Loc:2025/ 8/30 7:30:39 ) (UTC:2025/ 8/30 11:30:39 ) F:0
02: D7 10 00 00 0:03:25.238 HWM_main Cable Type Connected: None (None)
03: D7 10 00 00 0:03:25.484 HWM_main Cable Type Connected: Standard (500mA)
04: D7 10 00 00 0:03:34.033 HWM_main Cable Type Connected: None (None)
05: D7 10 00 00 0:03:35.319 HWM_main Cable Type Connected: Standard (500mA)
06: D7 10 00 00 0:03:42.091 HWM_main Cable Type Connected: None (None)
07: D7 10 00 00 0:03:44.601 HWM_main Cable Type Connected: Standard (500mA)
08: FE 01 02 00 0:03:48.019 SYC main 2025/ 8/30 11:34:15 V:4349
09: FF 00 00 00 0:00:00.798 SYC main 2025/ 8/30 11:34:15 C:314
0A: D7 10 00 00 0:00:00.862 HWM_usb_ Cable Type Connected: None (None)
0B: D7 10 00 00 0:00:01.250 HWM_main Cable Type Connected: None (500mA)
0C: FE 01 02 00 0:00:42.731 SYC main 2025/ 8/30 11:34:57 V:4349
0D: FF 00 00 00 0:00:00.783 SYC main 2025/ 8/30 11:34:58 C:315
0E: D7 10 00 00 0:00:02.316 HWM_main Cable Type Connected: None (None)
0F: D7 10 00 00 0:00:02.537 HWM_main Cable Type Connected: Standard (500mA)
10: D3 10 00 00 0:00:13.860 HWM_blue (Loc:2025/ 8/30 7:35:12 ) (UTC:2025/ 8/30 11:35:12 ) F:0
11: FE 01 02 00 0:00:38.179 SYC main 2025/ 8/30 11:35:37 V:4349
12: FF 00 00 00 0:00:00.785 SYC main 2025/ 8/30 11:35:37 C:316
13: D7 10 00 00 0:00:00.834 HWM_usb_ Cable Type Connected: None (None)
14: D7 10 00 00 0:00:01.238 HWM_main Cable Type Connected: None (500mA)
15: FE 01 02 00 0:09:20.490 SYC main 2025/ 8/30 11:44:57 V:4344
16: FF 00 00 00 0:00:00.792 SYC main 2025/ 8/30 11:44:58 C:317
17: D3 10 00 00 0:00:14.967 HWM_blue (Loc:2025/ 8/30 7:45:12 ) (UTC:2025/ 8/30 11:45:12 ) F:0
18: D3 10 00 00 0:16:56.002 HWM_blue (Loc:2025/ 8/30 8:01:54 ) (UTC:2025/ 8/30 12:01:54 ) F:0
19: FE 01 02 00 0:18:38.918 SYC main 2025/ 8/30 12:03:37 V:4315
1A: FF 00 00 00 0:00:00.784 SYC main 2025/ 8/30 14:57:50 C:318
1B: D3 10 00 00 0:00:14.328 HWM_blue (Loc:2025/ 8/30 10:58:04 ) (UTC:2025/ 8/30 14:58:04 ) F:0
1C: FE 01 02 00 3:16:52.176 SYC main 2025/ 8/30 18:14:42 V:4175
1D: FF 00 00 00 0:00:00.786 SYC main 2025/ 8/30 21:22:19 C:319
1E: D7 10 00 00 0:00:01.035 HWM_main Cable Type Connected: None (None)
1F: D7 10 00 00 0:00:01.235 HWM_main Cable Type Connected: Standard (500mA)
20: D3 10 00 00 0:00:12.760 HWM_blue (Loc:2025/ 8/30 17:22:31 ) (UTC:2025/ 8/30 21:22:31 ) F:0
21: FE 01 02 00 0:03:43.254 SYC main 2025/ 8/30 21:26:02 V:4336
22: FF 00 00 00 0:00:00.796 SYC main 2025/ 8/30 21:26:03 C:320
23: D7 10 00 00 0:00:01.044 HWM_main Cable Type Connected: None (None)
24: D7 10 00 00 0:00:01.244 HWM_main Cable Type Connected: None (500mA)
25: FE 01 02 00 0:25:13.174 SYC main 2025/ 8/30 21:51:15 V:4348
26: FF 00 00 00 0:00:00.788 SYC main 2025/ 8/31 14:57:33 C:321
27: D3 10 00 00 0:00:13.184 HWM_blue (Loc:2025/ 8/31 10:57:46 ) (UTC:2025/ 8/31 14:57:46 ) F:0
28: FE 02 02 00 3:11:39.734 PWR main 2025/ 8/31 18:09:12 V:4173
29: FF 02 02 00 3:11:42.217 PWR main 2025/ 8/31 18:58:32 C:322
2A: D7 10 00 00 3:11:42.226 HWM_main Cable Type Connected: None (None)
2B: D7 10 00 00 3:11:42.761 HWM_main Cable Type Connected: Standard (500mA)
2C: FE 02 02 00 3:56:50.448 PWR main 2025/ 8/31 19:43:40 V:4349
2D: D7 10 00 00 3:58:15.598 HWM_main Cable Type Connected: None (None)
2E? FF 02 02 00 3:59:04.280 PWR main 2025/ 9/ 1 13:25:38 C:323
2F: D3 10 00 00 3:59:09.778 HWM_blue (Loc:2025/ 9/ 1 9:25:43 ) (UTC:2025/ 9/ 1 13:25:43 ) F:0
30: FE 02 02 00 4:04:24.312 PWR main 2025/ 9/ 1 13:30:57 V:4305
31: FF 02 02 00 4:04:25.226 PWR main 2025/ 9/ 1 13:34:02 C:324
32: D3 10 00 00 4:04:29.394 HWM_blue (Loc:2025/ 9/ 1 9:34:06 ) (UTC:2025/ 9/ 1 13:34:06 ) F:0
33: D3 10 00 00 4:32:39.591 HWM_blue (Loc:2025/ 9/ 1 10:02:18 ) (UTC:2025/ 9/ 1 14:02:18 ) F:0
34: FE 01 02 00 5:23:17.281 SYC main 2025/ 9/ 1 14:52:55 V:4256
35: FF 00 00 00 0:00:00.795 SYC main 2025/ 9/ 1 14:52:59 C:325
36: D3 10 00 00 0:00:11.654 HWM_blue (Loc:2025/ 9/ 1 10:53:11 ) (UTC:2025/ 9/ 1 14:53:11 ) F:0
37: FE 02 02 00 1:13:49.031 PWR main 2025/ 9/ 1 16:06:48 V:4207
38: FF 02 02 00 1:13:49.944 PWR main 2025/ 9/ 1 21:11:05 C:326
39: D3 10 00 00 1:13:54.013 HWM_blue (Loc:2025/ 9/ 1 17:11:09 ) (UTC:2025/ 9/ 1 21:11:09 ) F:0
3A: FE 02 02 00 1:30:40.174 PWR main 2025/ 9/ 1 21:27:55 V:4185
3B: FF 02 02 00 1:30:42.586 PWR main 2025/ 9/ 2 1:56:04 C:327
3C: D7 10 00 00 1:30:42.596 HWM_main Cable Type Connected: None (None)
3D: D7 10 00 00 1:30:43.139 HWM_main Cable Type Connected: Standard (500mA)
3E: D3 10 00 00 2:09:36.432 HWM_blue (Loc:2025/ 9/ 1 22:34:58 ) (UTC:2025/ 9/ 2 2:34:58 ) F:0
3F: FE 02 02 00 2:09:50.826 PWR main 2025/ 9/ 2 2:35:12 V:4349
40: D7 10 00 00 2:11:15.894 HWM_main Cable Type Connected: None (None)
41? FF 02 02 00 2:11:31.060 PWR main 2025/ 9/ 2 19:32:25 C:328
42: D3 10 00 00 2:11:35.537 HWM_blue (Loc:2025/ 9/ 2 15:32:30 ) (UTC:2025/ 9/ 2 19:32:30 ) F:0
43? FF 00 00 00 0:00:00.781 SYC main 2025/ 9/ 2 19:33:37 C:329
44: D3 10 00 00 0:00:11.900 HWM_blue (Loc:2025/ 9/ 2 15:33:48 ) (UTC:2025/ 9/ 2 19:33:48 ) F:0
45: D3 10 00 00 0:00:49.118 HWM_wifi (Loc:2025/ 9/ 2 15:34:26 ) (UTC:2025/ 9/ 2 19:34:26 ) F:0
46: D7 10 00 00 0:13:05.976 HWM_main Cable Type Connected: None (None)
47: D7 10 00 00 0:13:06.229 HWM_main Cable Type Connected: Standard (500mA)
ownerID: 00000014
OwnerName: BARO
status: 01
pri_thresh: 2
archived: 00
max_arch: 08
num_recs: 0A
rec_size: 20
next_evnt: 09
timeDay: 2025/ 9/ 2 19:33:46
cycle_cnt: 329
09: F1 14 00 00 1:18:11.272 SNS_CAL 00000000000000000000000000000000 ................
00: F1 14 00 00 1:18:34.433 SNS_CAL 00000000000000000000000000000000 ................
01: D0 14 00 00 1:23:27.732 SNS_CAL Baro Activity Start Cal: 171.371994
02: FE 02 14 00 1:30:40.176 PWR main 2025/ 9/ 1 21:27:55 V:4185
03: FF 02 14 00 1:30:42.587 PWR main 2025/ 9/ 2 1:56:04 C:327
04: FE 02 14 00 2:09:50.827 PWR main 2025/ 9/ 2 2:35:12 V:4349
05: FF 02 14 00 2:11:31.061 PWR main 2025/ 9/ 2 19:32:25 C:328
06: D0 17 00 00 2:12:28.591 SNS_CAL Baro Activity Start Cal: 198.932312
07? FF 00 00 00 0:00:02.121 SNS_CAL 2025/ 9/ 2 19:33:39 C:329
08: D0 16 00 00 0:00:09.008 SNS_CAL Baro Activity Start Cal: 198.932312
ownerID: 00000016
OwnerName: Livetrack
status: 13
pri_thresh: 2
archived: 00
max_arch: 00
num_recs: FA
rec_size: 20
next_evnt: C9
timeDay: 2025/ 9/ 2 19:46:53
cycle_cnt: 329
C9: D1 10 F7 00 0:10:46.383 HWM_misc
CA: D1 18 F7 00 0:15:59.988 HWM_misc
CB: D1 17 F7 00 0:17:48.936 HWM_misc
CC: D1 10 F7 00 0:17:48.992 HWM_misc
CD: D1 18 F7 00 2:32:23.121 HWM_misc
CE: D1 17 F7 00 2:34:00.235 HWM_misc
CF: D1 10 F7 00 2:34:00.280 HWM_misc
D0: D1 18 F7 00 2:34:47.302 HWM_misc
D1: D1 17 F7 00 2:35:23.279 HWM_misc
D2: D1 10 F7 00 2:35:23.280 HWM_misc
D3: D1 18 F7 00 2:37:49.838 HWM_misc
D4: D1 17 F7 00 2:38:12.390 HWM_misc
D5: D1 10 F7 00 2:38:12.392 HWM_misc
D6: D1 18 F7 00 2:39:15.423 HWM_misc
D7: D1 17 F7 00 2:43:13.906 HWM_misc
D8: D1 10 F7 00 2:43:13.908 HWM_misc
D9: D1 18 F7 00 3:55:45.820 HWM_misc
DA: D1 17 F7 00 3:56:29.540 HWM_misc
DB: D1 10 F7 00 3:56:29.543 HWM_misc
DC: D1 18 F7 00 4:00:08.343 HWM_misc
DD: D1 17 F7 00 4:47:39.942 HWM_misc
DE: D1 10 F7 00 4:47:39.943 HWM_misc
DF: D1 18 F7 00 4:47:49.284 HWM_misc
E0: D1 17 F7 00 4:49:32.776 HWM_misc
E1: D1 10 F7 00 4:49:32.812 HWM_misc
E2: D1 18 F7 00 4:50:51.483 HWM_misc
E3: D1 17 F7 00 4:51:53.127 HWM_misc
E4: D1 10 F7 00 4:51:53.130 HWM_misc
E5: D1 18 F7 00 4:52:07.036 HWM_misc
E6: D1 17 F7 00 4:52:21.061 HWM_misc
E7: D1 10 F7 00 4:52:21.064 HWM_misc
E8: D1 18 F7 00 4:55:03.923 HWM_misc
E9: D1 17 F7 00 4:55:12.796 HWM_misc
EA: D1 10 F7 00 4:55:12.833 HWM_misc
EB: D1 18 F7 00 5:56:57.148 HWM_misc
EC: D1 17 F7 00 5:57:32.625 HWM_misc
ED: D1 10 F7 00 5:57:32.628 HWM_misc
EE: D1 18 F7 00 5:59:16.195 HWM_misc
EF: D1 17 F7 00 6:01:36.454 HWM_misc
F0: D1 10 F7 00 6:01:36.504 HWM_misc
F1: D1 18 F7 00 6:01:44.958 HWM_misc
F2: D1 17 F7 00 6:03:05.862 HWM_misc
F3: D1 10 F7 00 6:03:05.864 HWM_misc
F4: D1 18 F7 00 6:03:48.438 HWM_misc
F5: D1 17 F7 00 6:04:37.366 HWM_misc
F6: D1 10 F7 00 6:04:37.368 HWM_misc
F7: D1 18 F7 00 9:34:49.898 HWM_misc
F8: D1 17 F7 00 9:36:49.591 HWM_misc
F9: D1 10 F7 00 9:36:49.647 HWM_misc
00: D1 18 F7 00 9:37:08.322 HWM_misc
01: D1 17 F7 00 9:42:11.619 HWM_misc
02: D1 10 F7 00 9:42:11.654 HWM_misc
03: D1 18 F7 00 9:42:21.171 HWM_misc
04: D1 17 F7 00 9:42:36.483 HWM_misc
05: D1 10 F7 00 9:42:36.485 HWM_misc
06: D1 18 F7 00 9:43:11.133 HWM_misc
07: D1 17 F7 00 9:45:09.558 HWM_misc
08: D1 10 F7 00 9:45:09.559 HWM_misc
09: D1 18 F7 00 12:12:34.196 HWM_misc
0A: D1 17 F7 00 12:57:41.193 HWM_misc
0B: D1 10 F7 00 12:57:41.196 HWM_misc
0C: D1 18 F7 00 12:57:49.644 HWM_misc
0D: D1 17 03 01 0:00:20.878 HWM_misc
0E: D1 10 03 01 0:00:20.888 HWM_misc
0F: D1 17 05 01 0:00:19.937 HWM_misc
10: D1 10 05 01 0:00:19.938 HWM_misc
11: D1 17 06 01 0:00:20.413 HWM_misc
12: D1 10 06 01 0:00:20.414 HWM_misc
13: D1 17 08 01 0:00:15.948 HWM_misc
14: D1 10 08 01 0:00:15.952 HWM_misc
15: D1 17 09 01 0:00:25.234 HWM_misc
16: D1 10 09 01 0:00:25.235 HWM_misc
17: D1 17 0A 01 0:00:19.938 HWM_misc
18: D1 10 0A 01 0:00:19.938 HWM_misc
19: D1 17 0B 01 0:00:18.113 HWM_misc
1A: D1 10 0B 01 0:00:18.114 HWM_misc
1B: D1 18 0B 01 0:03:08.718 HWM_misc
1C: D1 17 0B 01 0:04:25.364 HWM_misc
1D: D1 10 0B 01 0:04:25.366 HWM_misc
1E: D1 18 0B 01 0:05:58.171 HWM_misc
1F: D1 17 0B 01 0:06:26.020 HWM_misc
20: D1 10 0B 01 0:06:26.023 HWM_misc
21: D1 18 0B 01 0:06:33.816 HWM_misc
22: D1 17 0B 01 0:07:09.567 HWM_misc
23: D1 10 0B 01 0:07:09.604 HWM_misc
24: D1 18 0B 01 2:16:59.854 HWM_misc
25: D1 17 0B 01 2:31:19.220 HWM_misc
26: D1 10 0B 01 2:31:19.264 HWM_misc
27: D1 17 0E 01 0:00:15.858 HWM_misc
28: D1 10 0E 01 0:00:15.859 HWM_misc
29* 12 12 0E 01 0:01:20.754 HWM_misc Request Error 0
2A: D1 18 0E 01 0:01:20.760 HWM_misc
2B: D1 17 0E 01 0:01:26.742 HWM_misc
2C: D1 10 0E 01 0:01:26.744 HWM_misc
2D: D1 18 0E 01 0:01:58.112 HWM_misc
2E: D1 17 0E 01 0:02:12.615 HWM_misc
2F: D1 10 0E 01 0:02:12.618 HWM_misc
30: D1 18 0E 01 2:49:58.737 HWM_misc
31: D1 17 0E 01 3:37:08.629 HWM_misc
32: D1 10 0E 01 3:37:08.630 HWM_misc
33: D1 18 0E 01 3:37:19.543 HWM_misc
34: D1 17 0E 01 3:39:23.748 HWM_misc
35: D1 10 0E 01 3:39:23.774 HWM_misc
36: D1 18 0E 01 6:00:48.614 HWM_misc
37: D1 17 0E 01 6:00:59.996 HWM_misc
38: D1 10 0E 01 6:00:59.999 HWM_misc
39: D1 18 0E 01 6:03:28.195 HWM_misc
3A: D1 17 0E 01 6:44:07.838 HWM_misc
3B: D1 10 0E 01 6:44:07.841 HWM_misc
3C: D1 18 0E 01 6:44:19.736 HWM_misc
3D: D1 17 0E 01 6:45:30.908 HWM_misc
3E: D1 10 0E 01 6:45:30.938 HWM_misc
3F: D1 18 0E 01 7:06:43.550 HWM_misc
40: D1 17 0E 01 7:08:36.947 HWM_misc
41: D1 10 0E 01 7:08:36.976 HWM_misc
42: D1 18 0E 01 7:11:10.532 HWM_misc
43: D1 17 0E 01 7:12:04.809 HWM_misc
44: D1 10 0E 01 7:12:04.810 HWM_misc
45: D1 17 15 01 0:00:16.597 HWM_misc
46: D1 10 15 01 0:00:16.606 HWM_misc
47: D1 18 15 01 1:49:54.962 HWM_misc
48: D1 17 15 01 1:51:14.002 HWM_misc
49: D1 10 15 01 1:51:14.059 HWM_misc
4A: D1 17 17 01 0:00:20.540 HWM_misc
4B: D1 10 17 01 0:00:20.541 HWM_misc
4C: D1 17 18 01 0:00:16.580 HWM_misc
4D: D1 10 18 01 0:00:16.581 HWM_misc
4E: D1 17 1A 01 0:00:20.223 HWM_misc
4F: D1 10 1A 01 0:00:20.223 HWM_misc
50* 12 12 1A 01 0:01:21.333 HWM_misc Request Error 0
51: D1 17 1B 01 0:00:14.845 HWM_misc
52: D1 10 1B 01 0:00:14.846 HWM_misc
53: D1 18 1B 01 2:50:57.042 HWM_misc
54: D1 17 1B 01 2:51:10.793 HWM_misc
55: D1 10 1B 01 2:51:10.837 HWM_misc
56: D1 18 1B 01 2:52:02.720 HWM_misc
57: D1 17 1B 01 2:52:31.941 HWM_misc
58: D1 10 1B 01 2:52:31.955 HWM_misc
59: D1 17 1D 01 0:00:20.227 HWM_misc
5A: D1 10 1D 01 0:00:20.235 HWM_misc
5B: D1 18 1D 01 0:05:59.098 HWM_misc
5C: D1 17 1D 01 0:07:48.378 HWM_misc
5D: D1 10 1D 01 0:07:48.429 HWM_misc
5E: D1 18 1D 01 1:00:56.744 HWM_misc
5F: D1 17 1D 01 1:01:04.282 HWM_misc
60: D1 10 1D 01 1:01:04.284 HWM_misc
61: D1 18 1D 01 1:33:02.551 HWM_misc
62: D1 17 1D 01 1:34:35.522 HWM_misc
63: D1 10 1D 01 1:34:35.690 HWM_misc
64: D1 18 1D 01 2:43:53.074 HWM_misc
65: D1 17 1D 01 2:44:46.800 HWM_misc
66: D1 10 1D 01 2:44:46.801 HWM_misc
67: D1 17 21 01 0:00:16.481 HWM_misc
68: D1 10 21 01 0:00:16.481 HWM_misc
69: D1 17 22 01 0:00:17.493 HWM_misc
6A: D1 10 22 01 0:00:17.498 HWM_misc
6B: D1 17 23 01 0:00:18.147 HWM_misc
6C: D1 10 23 01 0:00:18.151 HWM_misc
6D: D1 17 24 01 0:00:17.425 HWM_misc
6E: D1 10 24 01 0:00:17.429 HWM_misc
6F: D1 17 25 01 0:00:16.791 HWM_misc
70: D1 10 25 01 0:00:16.794 HWM_misc
71: D1 17 26 01 0:00:17.772 HWM_misc
72: D1 10 26 01 0:00:17.776 HWM_misc
73: D1 17 27 01 0:00:16.405 HWM_misc
74: D1 10 27 01 0:00:16.405 HWM_misc
75: D1 18 27 01 0:23:11.904 HWM_misc
76: D1 17 27 01 0:23:20.661 HWM_misc
77: D1 10 27 01 0:23:20.664 HWM_misc
78: D1 17 28 01 0:00:17.749 HWM_misc
79: D1 10 28 01 0:00:17.753 HWM_misc
7A: D1 17 29 01 0:00:14.370 HWM_misc
7B: D1 10 29 01 0:00:14.371 HWM_misc
7C: D1 17 2B 01 0:00:22.974 HWM_misc
7D: D1 10 2B 01 0:00:22.975 HWM_misc
7E: D1 17 2C 01 0:02:26.181 HWM_misc
7F: D1 10 2C 01 0:02:26.182 HWM_misc
80: D1 17 2C 01 0:03:56.227 HWM_misc
81: D1 18 2C 01 0:03:56.294 HWM_misc
82: D1 17 2D 01 0:00:15.482 HWM_misc
83: D1 17 2D 01 0:00:16.725 HWM_misc
84: D1 10 2D 01 0:00:16.728 HWM_misc
85: D1 17 2E 01 0:01:22.512 HWM_misc
86: D1 10 2E 01 0:01:22.513 HWM_misc
87: D1 17 2E 01 0:02:54.857 HWM_misc
88: D1 18 2E 01 0:02:54.907 HWM_misc
89: D1 18 2E 01 0:05:47.949 HWM_misc
8A: D1 17 30 01 0:00:32.247 HWM_misc
8B: D1 17 30 01 0:00:33.260 HWM_misc
8C: D1 10 30 01 0:00:33.261 HWM_misc
8D: D1 18 30 01 0:00:51.751 HWM_misc
8E: D1 17 32 01 0:00:14.854 HWM_misc
8F: D1 10 32 01 0:00:14.855 HWM_misc
90: D1 17 32 01 0:00:16.621 HWM_misc
91: D1 18 32 01 0:00:49.507 HWM_misc
92: D1 17 32 01 0:01:58.932 HWM_misc
93: D1 18 32 01 0:02:01.304 HWM_misc
94: D1 18 32 01 0:06:20.847 HWM_misc
95: D1 17 32 01 0:06:50.729 HWM_misc
96: D1 10 32 01 0:06:50.739 HWM_misc
97: D1 17 33 01 0:00:17.691 HWM_misc
98: D1 17 33 01 0:00:18.890 HWM_misc
99: D1 10 33 01 0:00:18.893 HWM_misc
9A: D1 18 33 01 0:01:07.588 HWM_misc
9B: D1 17 35 01 0:00:20.355 HWM_misc
9C: D1 10 35 01 0:00:20.356 HWM_misc
9D: D1 17 37 01 0:00:14.781 HWM_misc
9E: D1 10 37 01 0:00:14.781 HWM_misc
9F: D1 18 37 01 0:01:02.592 HWM_misc
A0: D1 17 39 01 0:00:14.400 HWM_misc
A1: D1 10 39 01 0:00:14.401 HWM_misc
A2: D1 18 39 01 0:03:37.704 HWM_misc
A3: D1 17 3B 01 0:00:16.302 HWM_misc
A4: D1 10 3B 01 0:00:16.303 HWM_misc
A5: D1 17 3D 01 0:00:17.262 HWM_misc
A6: D1 10 3D 01 0:00:17.264 HWM_misc
A7: D1 18 3D 01 0:16:53.360 HWM_misc
A8: D1 17 3D 01 0:16:57.564 HWM_misc
A9: D1 10 3D 01 0:16:57.565 HWM_misc
AA: D1 17 3E 01 0:00:16.634 HWM_misc
AB: D1 10 3E 01 0:00:16.650 HWM_misc
AC: D1 17 3F 01 0:00:20.513 HWM_misc
AD: D1 10 3F 01 0:00:20.514 HWM_misc
AE: D1 17 41 01 0:00:20.255 HWM_misc
AF: D1 10 41 01 0:00:20.256 HWM_misc
B0: D1 18 41 01 3:11:38.317 HWM_misc
B1: D1 17 41 01 3:59:11.437 HWM_misc
B2: D1 10 41 01 3:59:11.496 HWM_misc
B3: D1 18 41 01 4:04:22.839 HWM_misc
B4: D1 17 41 01 4:04:30.762 HWM_misc
B5: D1 10 41 01 4:04:30.791 HWM_misc
B6: D1 18 41 01 4:32:36.424 HWM_misc
B7: D1 17 41 01 4:32:41.447 HWM_misc
B8: D1 10 41 01 4:32:41.450 HWM_misc
B9: D1 17 45 01 0:00:15.899 HWM_misc
BA: D1 10 45 01 0:00:15.900 HWM_misc
BB: D1 18 45 01 1:13:47.640 HWM_misc
BC: D1 17 45 01 1:13:55.769 HWM_misc
BD: D1 10 45 01 1:13:55.808 HWM_misc
BE: D1 18 45 01 1:30:38.772 HWM_misc
BF: D1 17 45 01 2:09:37.750 HWM_misc
C0: D1 10 45 01 2:09:37.751 HWM_misc
C1: D1 18 45 01 2:09:49.551 HWM_misc
C2: D1 17 45 01 2:11:36.856 HWM_misc
C3: D1 10 45 01 2:11:36.905 HWM_misc
C4: D1 17 49 01 0:00:15.706 HWM_misc
C5: D1 10 49 01 0:00:15.711 HWM_misc
C6: D1 17 49 01 0:00:46.041 HWM_misc
C7: D1 18 49 01 0:01:07.140 HWM_misc
C8: D1 18 49 01 0:13:16.004 HWM_misc
ownerID: 00000018
OwnerName: Incident
status: 11
pri_thresh: 2
archived: 00
max_arch: 00
num_recs: 80
rec_size: 40
next_evnt: 4B
timeDay: 2025/ 9/ 2 19:33:55
cycle_cnt: 329
4B: F1 18 F7 00 0:00:12.027 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
4C: D1 12 F7 00 0:00:23.415 BTF main 1124304403 BTF Protobuf state:0 IncidentStatusNotification: FINISH
4D: D1 12 F7 00 0:04:05.918 BTF main 1124304626 BTF Protobuf state:0 IncidentStatusNotification: FINISH
4E: D1 12 F7 00 0:10:48.573 BTF main 1124305680 BTF Protobuf state:0 IncidentStatusNotification: FINISH
4F: D1 12 F7 00 0:17:52.348 BTF main 1124370137 BTF Protobuf state:0 IncidentStatusNotification: FINISH
50: D1 12 F7 00 2:35:38.333 BTF main 1124378403 BTF Protobuf state:0 IncidentStatusNotification: FINISH
51: D1 12 F7 00 2:38:18.261 BTF main 1124378563 BTF Protobuf state:0 IncidentStatusNotification: FINISH
52: D1 12 F7 00 2:43:16.440 BTF main 1124378861 BTF Protobuf state:0 IncidentStatusNotification: FINISH
53: D1 12 F7 00 3:56:34.560 BTF main 1124383259 BTF Protobuf state:0 IncidentStatusNotification: FINISH
54: D1 12 F7 00 4:47:43.500 BTF main 1124388818 BTF Protobuf state:0 IncidentStatusNotification: FINISH
55: D1 12 F7 00 4:49:36.431 BTF main 1124475372 BTF Protobuf state:0 IncidentStatusNotification: FINISH
56: D1 12 F7 00 4:52:24.520 BTF main 1124475540 BTF Protobuf state:0 IncidentStatusNotification: FINISH
57: D1 12 F7 00 4:55:16.013 BTF main 1124475815 BTF Protobuf state:0 IncidentStatusNotification: FINISH
58: D1 12 F7 00 5:57:41.788 BTF main 1124479561 BTF Protobuf state:0 IncidentStatusNotification: FINISH
59: D1 12 F7 00 6:03:09.562 BTF main 1124550940 BTF Protobuf state:0 IncidentStatusNotification: FINISH
5A: D1 12 F7 00 6:04:41.361 BTF main 1124551032 BTF Protobuf state:0 IncidentStatusNotification: FINISH
5B: D1 12 F7 00 9:36:53.197 BTF main 1124652703 BTF Protobuf state:0 IncidentStatusNotification: FINISH
5C: D1 12 F7 00 9:42:39.650 BTF main 1124653207 BTF Protobuf state:0 IncidentStatusNotification: FINISH
5D: D1 12 F7 00 9:45:12.871 BTF main 1124653360 BTF Protobuf state:0 IncidentStatusNotification: FINISH
5E: D1 12 F7 00 12:57:45.433 BTF main 1124666576 BTF Protobuf state:0 IncidentStatusNotification: FINISH
5F: F1 18 03 01 0:00:12.222 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
60: D1 12 03 01 0:00:24.044 BTF main 1124738572 BTF Protobuf state:0 IncidentStatusNotification: FINISH
61: F1 18 05 01 0:00:11.765 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
62: D1 12 05 01 0:00:23.928 BTF main 1124739260 BTF Protobuf state:0 IncidentStatusNotification: FINISH
63: F1 18 06 01 0:00:11.788 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
64: D1 12 06 01 0:00:20.474 BTF main 1124739453 BTF Protobuf state:0 IncidentStatusNotification: FINISH
65: F1 18 08 01 0:00:12.753 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
66: D1 12 08 01 0:00:19.811 BTF main 1124739570 BTF Protobuf state:0 IncidentStatusNotification: FINISH
67: F1 18 09 01 0:00:13.565 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
68: D1 12 09 01 0:00:29.452 BTF main 1124739703 BTF Protobuf state:0 IncidentStatusNotification: FINISH
69: F1 18 0A 01 0:00:10.997 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
6A: D1 12 0A 01 0:00:23.694 BTF main 1124801861 BTF Protobuf state:0 IncidentStatusNotification: FINISH
6B: F1 18 0B 01 0:00:10.535 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
6C: D1 12 0B 01 0:00:22.336 BTF main 1124803607 BTF Protobuf state:0 IncidentStatusNotification: FINISH
6D: D1 12 0B 01 0:04:28.676 BTF main 1124803854 BTF Protobuf state:0 IncidentStatusNotification: FINISH
6E: D1 12 0B 01 0:07:12.880 BTF main 1124804614 BTF Protobuf state:0 IncidentStatusNotification: FINISH
6F: D1 12 0B 01 2:31:22.727 BTF main 1124823593 BTF Protobuf state:0 IncidentStatusNotification: FINISH
70: F1 18 0E 01 0:00:11.561 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
71: D1 12 0E 01 0:00:19.202 BTF main 1124902082 BTF Protobuf state:0 IncidentStatusNotification: FINISH
72: D1 12 0E 01 0:01:30.395 BTF main 1124902154 BTF Protobuf state:0 IncidentStatusNotification: FINISH
73: D1 12 0E 01 0:02:17.488 BTF main 1124902201 BTF Protobuf state:0 IncidentStatusNotification: FINISH
74: D1 12 0E 01 3:37:11.066 BTF main 1124932618 BTF Protobuf state:0 IncidentStatusNotification: FINISH
75: D1 12 0E 01 3:39:26.720 BTF main 1124977529 BTF Protobuf state:0 IncidentStatusNotification: FINISH
76: D1 12 0E 01 6:01:05.619 BTF main 1124986029 BTF Protobuf state:0 IncidentStatusNotification: FINISH
77: D1 12 0E 01 6:44:11.443 BTF main 1124989554 BTF Protobuf state:0 IncidentStatusNotification: FINISH
78: D1 12 0E 01 6:45:34.026 BTF main 1125002417 BTF Protobuf state:0 IncidentStatusNotification: FINISH
79: D1 12 0E 01 7:08:41.032 BTF main 1125084962 BTF Protobuf state:0 IncidentStatusNotification: FINISH
7A: D1 12 0E 01 7:12:07.880 BTF main 1125085169 BTF Protobuf state:0 IncidentStatusNotification: FINISH
7B: F1 18 15 01 0:00:11.764 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
7C: D1 12 15 01 0:00:19.596 BTF main 1125169792 BTF Protobuf state:0 IncidentStatusNotification: FINISH
7D: D1 12 15 01 1:51:16.925 BTF main 1125179455 BTF Protobuf state:0 IncidentStatusNotification: FINISH
7E: F1 18 17 01 0:00:11.779 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
7F: D1 12 17 01 0:00:23.073 BTF main 1125241013 BTF Protobuf state:0 IncidentStatusNotification: FINISH
00: F1 18 18 01 0:00:11.021 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
01: D1 12 18 01 0:00:20.942 BTF main 1125242821 BTF Protobuf state:0 IncidentStatusNotification: FINISH
02: F1 18 1A 01 0:00:10.754 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
03: D1 12 1A 01 0:00:24.054 BTF main 1125258446 BTF Protobuf state:0 IncidentStatusNotification: FINISH
04: F1 18 1B 01 0:00:10.773 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
05: D1 12 1B 01 0:00:17.977 BTF main 1125261704 BTF Protobuf state:0 IncidentStatusNotification: FINISH
06: D1 12 1B 01 2:51:14.009 BTF main 1125274251 BTF Protobuf state:0 IncidentStatusNotification: FINISH
07: D1 12 1B 01 2:52:28.832 BTF main 1125274326 BTF Protobuf state:0 IncidentStatusNotification: FINISH
08: F1 18 1D 01 0:00:10.851 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
09: D1 12 1D 01 0:00:23.526 BTF main 1125274682 BTF Protobuf state:0 IncidentStatusNotification: FINISH
0A: D1 12 1D 01 0:07:52.325 BTF main 1125324257 BTF Protobuf state:0 IncidentStatusNotification: FINISH
0B: D1 12 1D 01 1:01:07.838 BTF main 1125327453 BTF Protobuf state:0 IncidentStatusNotification: FINISH
0C: D1 12 1D 01 1:34:40.200 BTF main 1125347134 BTF Protobuf state:0 IncidentStatusNotification: FINISH
0D: D1 12 1D 01 2:44:49.625 BTF main 1125351343 BTF Protobuf state:0 IncidentStatusNotification: FINISH
0E: F1 18 21 01 0:00:11.826 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
0F: D1 12 21 01 0:00:19.087 BTF main 1125419478 BTF Protobuf state:0 IncidentStatusNotification: FINISH
10: F1 18 22 01 0:00:11.442 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
11: D1 12 22 01 0:00:21.690 BTF main 1125419604 BTF Protobuf state:0 IncidentStatusNotification: FINISH
12: F1 18 23 01 0:00:11.128 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
13: D1 12 23 01 0:00:22.753 BTF main 1125421415 BTF Protobuf state:0 IncidentStatusNotification: FINISH
14: F1 18 24 01 0:00:11.786 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
15: D1 12 24 01 0:00:21.427 BTF main 1125421506 BTF Protobuf state:0 IncidentStatusNotification: FINISH
16: F1 18 25 01 0:00:11.786 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
17: D1 12 25 01 0:00:21.338 BTF main 1125421584 BTF Protobuf state:0 IncidentStatusNotification: FINISH
18: F1 18 26 01 0:00:11.552 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
19: D1 12 26 01 0:00:21.671 BTF main 1125423395 BTF Protobuf state:0 IncidentStatusNotification: FINISH
1A: F1 18 27 01 0:00:11.626 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
1B: D1 12 27 01 0:00:20.733 BTF main 1125425203 BTF Protobuf state:0 IncidentStatusNotification: FINISH
1C: D1 12 27 01 0:23:25.047 BTF main 1125426588 BTF Protobuf state:0 IncidentStatusNotification: FINISH
1D: F1 18 28 01 0:00:11.997 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
1E: D1 12 28 01 0:00:22.081 BTF main 1125427014 BTF Protobuf state:0 IncidentStatusNotification: FINISH
1F: F1 18 29 01 0:00:10.894 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
20: D1 12 29 01 0:00:17.980 BTF main 1125427619 BTF Protobuf state:0 IncidentStatusNotification: FINISH
21: F1 18 2B 01 0:00:14.976 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
22: D1 12 2B 01 0:00:26.116 BTF main 1125427961 BTF Protobuf state:0 IncidentStatusNotification: FINISH
23: F1 18 2C 01 0:00:14.876 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
24: D1 12 2C 01 0:02:21.042 BTF main 1125428245 BTF Protobuf state:0 IncidentStatusNotification: FINISH
25: F1 18 2D 01 0:00:09.853 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
26: D1 12 2D 01 0:00:19.036 BTF main 1125428569 BTF Protobuf state:0 IncidentStatusNotification: FINISH
27: F1 18 2E 01 0:00:13.106 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
28: D1 12 2E 01 0:01:17.910 BTF main 1125429054 BTF Protobuf state:0 IncidentStatusNotification: FINISH
29: F1 18 30 01 0:00:26.579 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
2A: D1 12 30 01 0:00:35.776 BTF main 1125429585 BTF Protobuf state:0 IncidentStatusNotification: FINISH
2B: F1 18 32 01 0:00:10.053 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
2C: D1 12 32 01 0:00:17.735 BTF main 1125429745 BTF Protobuf state:0 IncidentStatusNotification: FINISH
2D: D1 12 32 01 0:06:48.475 BTF main 1125430137 BTF Protobuf state:0 IncidentStatusNotification: FINISH
2E: F1 18 33 01 0:00:10.039 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
2F: D1 12 33 01 0:00:21.783 BTF main 1125430288 BTF Protobuf state:0 IncidentStatusNotification: FINISH
30: F1 18 35 01 0:00:10.430 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
31: D1 12 35 01 0:00:26.068 BTF main 1125487356 BTF Protobuf state:0 IncidentStatusNotification: FINISH
32: F1 18 37 01 0:00:10.342 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
33: D1 12 37 01 0:00:18.183 BTF main 1125487662 BTF Protobuf state:0 IncidentStatusNotification: FINISH
34: F1 18 39 01 0:00:09.957 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
35: D1 12 39 01 0:00:17.524 BTF main 1125487845 BTF Protobuf state:0 IncidentStatusNotification: FINISH
36: F1 18 3B 01 0:00:12.058 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
37: D1 12 3B 01 0:00:19.343 BTF main 1125488118 BTF Protobuf state:0 IncidentStatusNotification: FINISH
38: F1 18 3D 01 0:00:12.569 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
39: D1 12 3D 01 0:00:23.169 BTF main 1125488721 BTF Protobuf state:0 IncidentStatusNotification: FINISH
3A: D1 12 3D 01 0:17:01.997 BTF main 1125489720 BTF Protobuf state:0 IncidentStatusNotification: FINISH
3B: F1 18 3E 01 0:00:12.651 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
3C: D1 12 3E 01 0:00:19.600 BTF main 1125500289 BTF Protobuf state:0 IncidentStatusNotification: FINISH
3D: F1 18 3F 01 0:00:10.113 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
3E: D1 12 3F 01 0:00:26.207 BTF main 1125523365 BTF Protobuf state:0 IncidentStatusNotification: FINISH
3F: F1 18 41 01 0:00:11.055 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
40: D1 12 41 01 0:00:24.655 BTF main 1125586678 BTF Protobuf state:0 IncidentStatusNotification: FINISH
41: D1 12 41 01 3:59:14.409 BTF main 1125667548 BTF Protobuf state:0 IncidentStatusNotification: FINISH
42: D1 12 41 01 4:04:34.612 BTF main 1125668053 BTF Protobuf state:0 IncidentStatusNotification: FINISH
43: D1 12 41 01 4:32:44.077 BTF main 1125669742 BTF Protobuf state:0 IncidentStatusNotification: FINISH
44: F1 18 45 01 0:00:11.388 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
45: D1 12 45 01 0:00:18.974 BTF main 1125672798 BTF Protobuf state:0 IncidentStatusNotification: FINISH
46: D1 12 45 01 1:13:58.692 BTF main 1125695474 BTF Protobuf state:0 IncidentStatusNotification: FINISH
47: D1 12 45 01 2:09:40.722 BTF main 1125714903 BTF Protobuf state:0 IncidentStatusNotification: FINISH
48: D1 12 45 01 2:11:39.931 BTF main 1125775954 BTF Protobuf state:0 IncidentStatusNotification: FINISH
49: F1 18 49 01 0:00:10.463 SYC main 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ................................................
4A: D1 12 49 01 0:00:18.286 BTF main 1125776035 BTF Protobuf state:0 IncidentStatusNotification: FINISH
ownerID: 0000001B
OwnerName: JEFF
status: 01
pri_thresh: 2
archived: 04
max_arch: 20
num_recs: 20
rec_size: 40
next_evnt: 19
timeDay: 2025/ 9/ 2 19:33:43
cycle_cnt: 329
19: E0 00 00 00 0:00:06.241 HWM GFS CHKDSK Report: Vol:0 Time:3992msec Dirs:87 Files:604 Free:1007107 Diff:1007108
1A: FE 01 1B 00 0:18:38.919 SYC main 2025/ 8/30 12:03:37 V:4315
1B: FF 00 00 00 0:00:02.197 HWM GFS 2025/ 8/30 14:57:52 C:318
1C: DF 05 00 00 0:00:02.202 HWM GFS JEFF Vol:0 Journal entries: 0
1D: E0 00 00 00 0:00:06.195 HWM GFS CHKDSK Report: Vol:0 Time:3993msec Dirs:90 Files:607 Free:1006881 Diff:1006882
1E: FE 01 1B 00 3:16:52.177 SYC main 2025/ 8/30 18:14:42 V:4175
1F: FF 00 00 00 0:00:02.207 HWM GFS 2025/ 8/30 21:22:21 C:319
00: DF 05 00 00 0:00:02.212 HWM GFS JEFF Vol:0 Journal entries: 0
01: E0 00 00 00 0:00:06.211 HWM GFS CHKDSK Report: Vol:0 Time:3999msec Dirs:98 Files:634 Free:1003263 Diff:1003264
02: FE 01 1B 00 0:03:43.255 SYC main 2025/ 8/30 21:26:02 V:4336
03: FF 00 00 00 0:00:02.207 HWM GFS 2025/ 8/31 14:57:35 C:321
04: DF 05 00 00 0:00:02.212 HWM GFS JEFF Vol:0 Journal entries: 0
05: E0 00 00 00 0:00:06.221 HWM GFS CHKDSK Report: Vol:0 Time:4009msec Dirs:98 Files:639 Free:1003239 Diff:1003240
06: FE 02 1B 00 3:11:39.735 PWR main 2025/ 8/31 18:09:12 V:4173
07: FF 02 1B 00 3:11:42.218 PWR main 2025/ 8/31 18:58:32 C:322
08: FE 02 1B 00 3:56:50.450 PWR main 2025/ 8/31 19:43:40 V:4349
09: FF 02 1B 00 3:59:04.281 PWR main 2025/ 9/ 1 13:25:38 C:323
0A: FE 02 1B 00 4:04:24.314 PWR main 2025/ 9/ 1 13:30:57 V:4305
0B: FF 02 1B 00 4:04:25.226 PWR main 2025/ 9/ 1 13:34:02 C:324
0C: FE 01 1B 00 5:23:17.283 SYC main 2025/ 9/ 1 14:52:55 V:4256
0D: FF 00 00 00 0:00:02.213 HWM GFS 2025/ 9/ 1 14:53:01 C:325
0E: DF 05 00 00 0:00:02.218 HWM GFS JEFF Vol:0 Journal entries: 0
0F: E0 00 00 00 0:00:06.223 HWM GFS CHKDSK Report: Vol:0 Time:4005msec Dirs:96 Files:652 Free:1005149 Diff:1005150
10: FE 02 1B 00 1:13:49.032 PWR main 2025/ 9/ 1 16:06:48 V:4207
11: FF 02 1B 00 1:13:49.944 PWR main 2025/ 9/ 1 21:11:05 C:326
12: FE 02 1B 00 1:30:40.176 PWR main 2025/ 9/ 1 21:27:55 V:4185
13: FF 02 1B 00 1:30:42.587 PWR main 2025/ 9/ 2 1:56:04 C:327
14: FE 02 1B 00 2:09:50.827 PWR main 2025/ 9/ 2 2:35:12 V:4349
15: FF 02 1B 00 2:11:31.061 PWR main 2025/ 9/ 2 19:32:25 C:328
16? FF 00 00 00 0:00:02.238 HWM GFS 2025/ 9/ 2 19:33:39 C:329
17: DF 05 00 00 0:00:02.244 HWM GFS JEFF Vol:0 Journal entries: 0
18: E0 00 00 00 0:00:06.245 HWM GFS CHKDSK Report: Vol:0 Time:4001msec Dirs:99 Files:655 Free:1005915 Diff:1005916
>>>>> EVL_ARCH_LOGS <<<<<
ownerID: 0000001B
OwnerName: JEFF
status: 01
pri_thresh: 2
archived: 04
max_arch: 20
num_recs: 20
rec_size: 40
next_evnt: 00
timeDay: 2025/ 7/21 19:29:19
cycle_cnt: 25
00: FF 00 00 00 0:00:02.094 HWM GFS 2025/ 6/25 4:46:11 C:20
01: DF 05 00 00 0:00:02.099 HWM GFS JEFF Vol:0 Journal entries: 0
02: E0 00 00 00 0:00:07.265 HWM GFS CHKDSK Report: Vol:0 Time:5166msec Dirs:77 Files:418 Free:676434 Diff:676435
03: FE 01 1B 00 0:01:10.216 SYC main 2025/ 6/25 4:47:19 V:4138
04: FF 00 00 00 0:00:02.092 HWM GFS 2025/ 6/25 5:35:54 C:21
05: DF 05 00 00 0:00:02.097 HWM GFS JEFF Vol:0 Journal entries: 0
06: E0 00 00 00 0:00:07.269 HWM GFS CHKDSK Report: Vol:0 Time:5172msec Dirs:77 Files:420 Free:676431 Diff:676432
07: FE 01 1B 00 0:01:31.606 SYC main 2025/ 6/25 5:37:25 V:4217
08: FF 00 00 00 0:00:02.084 HWM GFS 2025/ 6/25 5:37:25 C:22
09: DF 05 00 00 0:00:02.089 HWM GFS JEFF Vol:0 Journal entries: 0
0A: E0 00 00 00 0:00:07.261 HWM GFS CHKDSK Report: Vol:0 Time:5172msec Dirs:77 Files:423 Free:676427 Diff:676428
0B: FE 01 1B 00 0:00:13.804 SYC main 2025/ 6/25 5:37:37 V:4223
0C: FF 00 00 00 0:00:02.131 HWM GFS 2025/ 6/25 5:37:39 C:23
0D: DF 05 00 00 0:00:02.135 HWM GFS JEFF Vol:0 Journal entries: 0
0E: E0 00 00 00 0:00:06.796 HWM GFS CHKDSK Report: Vol:0 Time:4661msec Dirs:77 Files:424 Free:676425 Diff:676426
0F: FE 01 1B 00 0:03:57.143 SYC main 2025/ 6/25 5:41:41 V:4204
10: FF 00 00 00 0:00:02.100 HWM GFS 2025/ 6/25 5:41:42 C:24
11: DF 05 00 00 0:00:02.105 HWM GFS JEFF Vol:0 Journal entries: 0
12: E0 00 00 00 0:00:06.542 HWM GFS CHKDSK Report: Vol:0 Time:4437msec Dirs:74 Files:364 Free:676550 Diff:676551
13: FE 01 1B 00 0:01:25.866 SYC main 2025/ 6/25 5:43:07 V:4234
14: FF 00 00 00 0:00:02.084 HWM GFS 2025/ 7/21 19:12:34 C:25
15: DF 05 00 00 0:00:02.088 HWM GFS JEFF Vol:0 Journal entries: 0
16: E0 00 00 00 0:00:06.526 HWM GFS CHKDSK Report: Vol:0 Time:4438msec Dirs:74 Files:362 Free:676553 Diff:676554
17* 15 23 00 00 0:08:16.680 BTF main 00000000FFFFFFFFFFFFAA55AA55B0770FD052780FD0FECCE6600100000010000000440000004352C38A504552455354 ...........U.U.w..Rx.....`........D...CR..PEREST
18* 15 23 00 00 0:08:21.667 BTF main 00000000FFFFFFFFFFFFAA55AA55203B25D09A3B25D0FECCE660010000000A00000028000000426F6F6B73746F726573 ...........U.U ;%..;%....`........(...Bookstores
19* 15 23 00 00 0:08:22.430 BTF main 00000000FFFFFFFFFFFFAA55AA5578D02AD1DAD02AD13CCDE6600100000008000000080000004C616E64666F726D00FF ...........U.Ux.*...*.<..`............Landform..
1A* 15 23 00 00 0:08:22.700 BTF main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55E0D90CD052DA0CD0AAF0CF60200000000000000042495400FFFF ...................U.U....R......` .......BIT...
1B* 15 23 00 00 0:08:26.615 BTF main 00000000FFFFFFFFFFFFAA55AA5578D02AD1DAD02AD13CCDE6600100000008000000080000004C616E64666F726D00FF ...........U.Ux.*...*.<..`............Landform..
1C* 15 23 00 00 0:08:32.064 BTF main 00000000FFFFFFFFFFFFAA55AA55B0B214D132B314D1FECCE660010000000B0000002C000000446976696E6720536974 ...........U.U....2......`........,...Diving Sit
1D* 15 23 00 00 0:08:32.736 BTF main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55A83B18D00A3C18D03CCDE6600100000008000000080000004169 ...................U.U.;...<..<..`............Ai
1E* 15 23 00 00 0:08:33.187 BTF main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA552042ADD0B242ADD0FECCE660010000000B00 ...........................U.U B...B.....`......
1F: FE 01 1B 00 0:16:44.253 SYC main 2025/ 7/21 19:29:19 V:3994
ownerID: 0000001B
OwnerName: JEFF
status: 01
pri_thresh: 2
archived: 04
max_arch: 20
num_recs: 20
rec_size: 40
next_evnt: 00
timeDay: 2025/ 8/29 18:55:12
cycle_cnt: 300
00: E2 00 00 00 0:00:06.324 HWM GFS CHKDSK Lost Clusters - vol_idx:0 cnt:1
01: E0 00 00 00 0:00:06.330 HWM GFS CHKDSK Report: Vol:0 Time:4072msec Dirs:101 Files:768 Free:959576 Diff:959577
02? FF 00 00 00 0:00:02.286 HWM GFS 2025/ 8/29 17:36:15 C:294
03: DF 05 00 00 0:00:02.291 HWM GFS JEFF Vol:0 Journal entries: 0
04: E2 00 00 00 0:00:06.297 HWM GFS CHKDSK Lost Clusters - vol_idx:0 cnt:1
05: E0 00 00 00 0:00:06.304 HWM GFS CHKDSK Report: Vol:0 Time:4013msec Dirs:101 Files:767 Free:1012780 Diff:1012781
06? FF 00 00 00 0:00:02.245 HWM GFS 2025/ 8/29 18:06:25 C:295
07: DF 05 00 00 0:00:02.250 HWM GFS JEFF Vol:0 Journal entries: 0
08: E2 00 00 00 0:00:06.255 HWM GFS CHKDSK Lost Clusters - vol_idx:0 cnt:1
09: E0 00 00 00 0:00:06.261 HWM GFS CHKDSK Report: Vol:0 Time:4011msec Dirs:101 Files:771 Free:1011816 Diff:1011817
0A? FF 00 00 00 0:00:02.304 HWM GFS 2025/ 8/29 18:36:34 C:296
0B: DF 05 00 00 0:00:02.309 HWM GFS JEFF Vol:0 Journal entries: 0
0C: E0 00 00 00 0:00:06.323 HWM GFS CHKDSK Report: Vol:0 Time:4014msec Dirs:101 Files:775 Free:1011322 Diff:1011323
0D: FE 01 1B 00 0:09:19.307 SYC main 2025/ 8/29 18:45:52 V:4180
0E: FF 00 00 00 0:00:02.293 HWM GFS 2025/ 8/29 18:46:44 C:297
0F: DF 05 00 00 0:00:02.298 HWM GFS JEFF Vol:0 Journal entries: 0
10: E0 00 00 00 0:00:06.295 HWM GFS CHKDSK Report: Vol:0 Time:3997msec Dirs:97 Files:747 Free:1013484 Diff:1013485
11: FE 01 1B 00 0:00:35.643 SYC main 2025/ 8/29 18:47:17 V:4299
12: FF 00 00 00 0:00:01.175 HWM GFS 2025/ 8/29 18:47:18 C:298
13: DF 05 00 00 0:00:01.180 HWM GFS JEFF Vol:0 Journal entries: 0
14: E0 00 00 00 0:00:05.161 HWM GFS CHKDSK Report: Vol:0 Time:3981msec Dirs:96 Files:752 Free:1013477 Diff:1013478
15: FE 01 1B 00 0:04:57.164 SYC main 2025/ 8/29 18:52:14 V:4316
16: FF 00 00 00 0:00:02.258 HWM GFS 2025/ 8/29 18:52:16 C:299
17: DF 05 00 00 0:00:02.262 HWM GFS JEFF Vol:0 Journal entries: 0
18: E0 00 00 00 0:00:06.259 HWM GFS CHKDSK Report: Vol:0 Time:3997msec Dirs:96 Files:710 Free:1016498 Diff:1016499
19: FE 01 1B 00 0:02:48.904 SYC main 2025/ 8/29 18:55:04 V:4213
1A: FF 00 00 00 0:00:02.182 HWM GFS 2025/ 8/29 18:55:06 C:300
1B: DF 05 00 00 0:00:02.187 HWM GFS JEFF Vol:0 Journal entries: 0
1C: E0 00 00 00 0:00:06.171 HWM GFS CHKDSK Report: Vol:0 Time:3984msec Dirs:97 Files:663 Free:1016640 Diff:1016641
1D* 15 23 00 00 0:00:08.052 SYC main 00000000FFFFC8521FD0C8521FD0A1F00F63AA55AA5578521FD0F0521FD0ADF00F6300000000FFFFFFFFFFFFFFFFFFFF .......R...R.....c.U.UxR...R.....c..............
1E* 15 23 00 00 0:00:08.053 SYC main 00000000FFFFFFFFFFFFFFFFAA55AA55205B1FD0805B1FD0A1F00F6300000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .............U.U [...[.....c....................
1F* 15 23 00 00 0:00:08.303 SYC main 000000000000AA55AA55D8A609D070A809D039F10F630000000000000000000000000000000000000000000000000000 .......U.U....p...9..c..........................
ownerID: 0000001B
OwnerName: JEFF
status: 01
pri_thresh: 2
archived: 04
max_arch: 20
num_recs: 20
rec_size: 40
next_evnt: 00
timeDay: 2025/ 8/29 19:09:45
cycle_cnt: 302
00* 15 23 00 00 0:00:08.312 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA5528C408D07AC408D08CE54160FFFF0200FFFFFFFFAA55AA5560C4 ...................U.U(...z.....A`.........U.U`.
01* 15 23 00 00 0:00:08.349 SYC main 00000000AA55AA5570983AD0AA55AA5508993AD050993AD095F00F631CFB0BD0FFFFFFFFFFFFFFFF38993AD0A59B3AD0 .....U.Up.:..U.U..:.P.:....c............8.:...:.
02* 15 23 00 00 0:00:08.354 SYC main 00000000000000000000AA55AA5540720AD008730AD0D5F00F6300000000000000000000000000000000000000000000 [email protected]......................
03* 15 23 00 00 0:00:08.363 SYC main 00000000F48B3BD0A08F3960AA55AA55588B3BD0F08B3BD0B9F00F6300000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ......;...9`.U.UX.;...;....c....................
04* 15 23 00 00 0:00:08.364 SYC main 00000000FFFFFFFFFFFFAA55AA5588730AD0DA730AD07A4B2D60C8730AD0C8730AD0AA55AA55C0730AD0F2730AD07A4B ...........U.U.s...s..zK-`.s...s...U.U.s...s..zK
05* 15 23 00 00 0:00:09.285 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA5510E20DD090E20DD0A1F00F63342C11D0FFFFFFFFFFFFFFFF .....................U.U...........c4,..........
06* 15 23 00 00 0:00:09.285 SYC main 00000000FFFFFFFFFFFFAA55AA55B8E60DD019E70DD0A2024E60FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ...........U.U..........N`......................
07* 15 23 00 00 0:00:11.206 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55508110D0F18110D0A08F3960FFFFFFFF .............................U.UP.........9`....
08* 15 23 00 00 0:00:11.281 SYC main 00000000FFFFFFFFAA55AA55C8DF3AD038E03AD0A5F00F6300000000A2024E60FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .........U.U..:.8.:....c......N`................
09* 15 23 00 00 0:00:11.286 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA5570F00FD001F10FD09000D760FFFFFFFF .............................U.Up..........`....
0A* 15 23 00 00 0:00:11.294 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55C02C3AD05A2D3AD064E541604072B861 .............................U.U.,:.Z-:.d.A`@r.a
0B* 15 23 00 00 0:00:11.645 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA5528AD0CD092AD0CD0314139606DAD0CD000000000FFFFFFFF .....................U.U(.......1A9`m...........
0C* 15 23 00 00 0:03:30.991 BTF main 00000000FFFFFFFFFFFFAA55AA557844F1D03245F1D0124BF260010000001A000000680000005075626C696320436F6D ...........U.UxD..2E...K.`........h...Public Com
0D: FE 01 1B 00 0:07:01.211 SYC main 2025/ 8/29 19:02:05 V:4179
0E: FF 00 00 00 0:00:02.194 HWM GFS 2025/ 8/29 19:02:32 C:301
0F: DF 05 00 00 0:00:02.199 HWM GFS JEFF Vol:0 Journal entries: 0
10: E0 00 00 00 0:00:06.159 HWM GFS CHKDSK Report: Vol:0 Time:3960msec Dirs:78 Files:471 Free:1023269 Diff:1023270
11: FE 01 1B 00 0:07:05.654 SYC main 2025/ 8/29 19:09:36 V:4191
12: FF 00 00 00 0:00:02.202 HWM GFS 2025/ 8/29 19:09:38 C:302
13: DF 05 00 00 0:00:02.207 HWM GFS JEFF Vol:0 Journal entries: 0
14: E0 00 00 00 0:00:06.164 HWM GFS CHKDSK Report: Vol:0 Time:3957msec Dirs:85 Files:561 Free:1022920 Diff:1022921
15* 15 23 00 00 0:00:08.475 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55B8120DD031130DD04840F260FFFFFFFFFFFFFFFFFFFFFFFFFFFF ...................U.U....1...H@.`..............
16* 15 23 00 00 0:00:08.476 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA5588671FD0F1671FD09E20D960FFFFFFFF .............................U.U.g...g... .`....
17* 15 23 00 00 0:00:08.525 SYC main 00000000FFFFAA55AA55584F1FD0A84F1FD095F00F631C4F1FD0FFFFFFFFFFFFFFFF904F1FD0CD4F1FD00A5F5460FFFF .......U.UXO...O.....c.O...........O...O..._T`..
18* 15 23 00 00 0:00:08.526 SYC main 00000000FFFFFFFFFFFFAA55AA5538751FD099751FD0A2024E60FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ...........U.U8u...u....N`......................
19* 15 23 00 00 0:00:08.546 SYC main 000000004761726D696E2F53AA55AA55B8050DD018060DD0A1F00F63000000006E47726F7570696E672E64622D6A6F75 ....Garmin/S.U.U...........c....nGrouping.db-jou
1A* 15 23 00 00 0:00:08.550 SYC main 00000000FFFFFFFFFFFFAA55AA55C0C21ED030C31ED0A9F00F6300000000FFFFFFFFFFFFFFFF68BC1ED030C31ED01823 ...........U.U....0......c............h...0....#
1B* 15 23 00 00 0:00:08.559 SYC main 00000000FFFFFFFFFFFFFFFFAA55AA55B8C90FD028CA0FD0A5F00F6300000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .............U.U....(......c....................
1C* 15 23 00 00 0:00:08.560 SYC main 00000000FFFF706D0DD0AA55AA55706D0DD0D06D0DD09DF00F634C520DD0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ......pm...U.Upm...m.....cLR....................
1D* 15 23 00 00 0:00:09.446 SYC main 00000000FFFFFFFFFFFFFFFFAA55AA5508EE0CD070EE0CD099F00F6334F81CD0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .............U.U....p......c4...................
1E* 15 23 00 00 0:00:09.447 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55201F1ED0811F1ED0A2024E60FFFFFFFFFFFFFFFFFFFFFFFFFFFF ...................U.U .........N`..............
1F* 15 23 00 00 0:00:09.452 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55C0391CD0393A1CD0A2024E60FFFFFFFF .............................U.U.9..9:....N`....
ownerID: 0000001B
OwnerName: JEFF
status: 01
pri_thresh: 2
archived: 04
max_arch: 20
num_recs: 20
rec_size: 40
next_evnt: 00
timeDay: 2025/ 8/30 11:22:46
cycle_cnt: 310
00* 15 23 00 00 0:00:09.466 SYC main 00000000FFFFFFFFFFFFFFFFAA55AA55D8501DD068511DD0ADF00F6300000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .............U.U.P..hQ.....c....................
01* 15 23 00 00 0:00:09.714 SYC main 00000000FFFFFFFFAA55AA55707112D0087212D0BDF00F6300000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .........U.Upq...r.....c........................
02* 15 23 00 00 0:00:09.831 SYC main 00000000FFFFFFFFAA55AA55D8740DD048750DD0A5F00F6300000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .........U.U.t..Hu.....c........................
03* 15 23 00 00 0:00:09.835 SYC main 00000000F4820DD0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA5528F813D099F813D0A2024E60FFFFFFFF .............................U.U(.........N`....
04* 15 23 00 00 0:00:09.984 SYC main 00000000FFFFFFFFFFFFFFFFAA55AA5518BE0CD0A8BE0CD0B9F00F6300000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF .............U.U...........c....................
05* 15 23 00 00 0:00:10.008 SYC main 00000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA55AA55F00001D0510101D0A2024E60FFFFFFFFFFFFFFFFFFFFFFFF .....................U.U....Q.....N`............
06: FE 01 1B 00 0:05:50.454 SYC main 2025/ 8/29 19:15:27 V:4268
07: FF 00 00 00 0:00:01.155 HWM GFS 2025/ 8/29 19:15:27 C:303
08: DF 05 00 00 0:00:01.160 HWM GFS JEFF Vol:0 Journal entries: 0
09: E0 00 00 00 0:00:05.105 HWM GFS CHKDSK Report: Vol:0 Time:3945msec Dirs:81 Files:489 Free:1023272 Diff:1023273
0A: FE 01 1B 00 0:03:42.527 SYC main 2025/ 8/29 19:19:09 V:4294
0B: FF 00 00 00 0:00:02.201 HWM GFS 2025/ 8/29 19:19:11 C:304
0C: DF 05 00 00 0:00:02.205 HWM GFS JEFF Vol:0 Journal entries: 0
0D: E0 00 00 00 0:00:06.205 HWM GFS CHKDSK Report: Vol:0 Time:4000msec Dirs:81 Files:552 Free:1007276 Diff:1007277
0E: FE 01 1B 00 0:00:55.138 SYC main 2025/ 8/29 19:20:05 V:4322
0F: FF 00 00 00 0:00:01.371 HWM GFS 2025/ 8/29 19:20:05 C:305
10: DF 05 00 00 0:00:01.375 HWM GFS JEFF Vol:0 Journal entries: 0
11: E0 00 00 00 0:00:05.349 HWM GFS CHKDSK Report: Vol:0 Time:3974msec Dirs:85 Files:559 Free:1007184 Diff:1007185
12: FE 01 1B 00 0:02:02.988 SYC main 2025/ 8/29 19:22:07 V:4315
13: FF 00 00 00 0:00:02.234 HWM GFS 2025/ 8/29 19:22:09 C:306
14: DF 05 00 00 0:00:02.239 HWM GFS JEFF Vol:0 Journal entries: 0
15: E0 00 00 00 0:00:06.232 HWM GFS CHKDSK Report: Vol:0 Time:3993msec Dirs:85 Files:559 Free:1007184 Diff:1007185
16: FE 01 1B 00 0:08:31.883 SYC main 2025/ 8/29 19:30:40 V:4208
17: FF 00 00 00 0:00:02.228 HWM GFS 2025/ 8/29 19:31:08 C:307
18: DF 05 00 00 0:00:02.233 HWM GFS JEFF Vol:0 Journal entries: 0
19: E0 00 00 00 0:00:06.223 HWM GFS CHKDSK Report: Vol:0 Time:3990msec Dirs:88 Files:572 Free:1007175 Diff:1007176
1A: FE 01 1B 00 0:08:49.636 SYC main 2025/ 8/29 19:39:56 V:4327
1B: FF 00 00 00 0:00:02.232 HWM GFS 2025/ 8/30 11:22:13 C:309
1C: DF 05 00 00 0:00:02.237 HWM GFS JEFF Vol:0 Journal entries: 0
1D: E0 00 00 00 0:00:06.225 HWM GFS CHKDSK Report: Vol:0 Time:3988msec Dirs:88 Files:598 Free:1007130 Diff:1007131
1E: FE 01 1B 00 0:00:33.870 SYC main 2025/ 8/30 11:22:44 V:4349
1F: FF 00 00 00 0:00:01.375 HWM GFS 2025/ 8/30 11:22:46 C:310
