Edge 540 + garmin trainer
I am using Garmin Trainer with the Connect app and an Edge 540, and I always have issues with syncing workouts. Every day they are present in the Connect app and on my watch, but not on the Edge 540.
  • sync triggered from app
  • sync triggered from Edge 540
  • using Express app
Also, fun fact, that whenever you add your own activity into calendar, it syncs in 5-10 seconds. So, to be honest, I don't understand what the problem Garmin devs have? Garmin training events are the same training as manually created in the calendar with few exceptions: you cannot remove them or reschedule.
Also, there is a specific point in the latest patch notes which says it was fixed, but it is not. I mean a €500+ device which cannot solve a simple issue with syncing calendars. Do any of Garmin's devs use their device?
The only way it works for me is to pause and resume the plan, but then it changes the workout immediately. So it could be intervals, but after pause/resume, it will become base or recovery. So this hack is not ideal.
Does garmin work on fixs? Or someone knows workaround?
