Edge 540 Series Version 26.16 - 20%
Changes made from version 25.25 to 26.16:
  • Added the ability to view future weather conditions for scheduled Garmin Coach Workouts
  • Added camera options to Edge Remote / Di2 Remote Actions
  • Added ability to schedule a software installation for after your ride
  • Added the ability to view Garmin Coach running and strength workouts within Edge calendars (supporting wearable required)
  • Added the ability to view multiple workouts scheduled on the same day within Edge calendars
  • Fixed Altimeter calibration menu night mode issues
  • Centered GroupRide rider list around user
  • Fixed gear details showing invalid data and gear data fields not populating data correctly for eBikes
  • Added connection type information for paired sensors
  • Fixed nutrition/hydration tracking if the unit is power cycled in the middle of an activity
  • Fixed pause during the update process before the unit reboots
  • Added support for HRM 200 pairing and data
  • Added ability to update Garmin power pedal scale factors with accuracy of 4 decimal places
  • Fixed issues with third-party workouts not syncing to device
  • Fixed climb pro lines being too thick as you zoom out on the map
  • Fixed intensity minutes glance displaying incorrect values
  • Improved the algorithm used to calculate the workout execution score
  • Fixed crash when cancelling Garmin Share transfer
  • Fixed various bugs and crashes
  • Added map data field
  • Fixed brightness jumping to 60% after being set to 0%
  • Added graphical compass data field
  • Fixed overlapping values on some graphical data fields
  • Fixed sizing differences with electronic shifting icons
  • Fixed extra small font sizes for units
  • Fixed text truncation issues on the software update page
Changes made from version 25.24 to 25.25:
  • Fix bundle update issue
Changes made from version 24.19 to 25.24:
  • Updated to MTP (Media Transfer Protocol).
  • GroupRide
    • Fixed GroupRide dynamic glance failing to update with finished ride data.
    • Fixed GroupRide awards getting reset after a power cycle.
  • Garmin Coach
    • Fixed an issue where the dynamic area would not update with the Garmin Coach workout.
    • Fixed Garmin Coach workout not showing as complete in the Garmin Coach glance.
    • Fixed issue where device wouldn't show some Garmin Coach plans in the Garmin Coach widget.
    • Fixed an issue where Garmin Coach workouts wouldn't sync.
  • Removed legacy FTP test.
  • Lactate Threshold estimates are applied automatically after training with heart rate.
  • Added a confirmation message for successful manual altimeter calibration.
  • Fixed double radar overlay in the Connect IQ Store.
  • Fixed pairing to inReach Messenger Plus.
  • Fix map track-line issues.
  • Fixed phone connectivity issue.
  • Fixed mismatching navigation arrow and distance to next arrow.
  • Fixed issue where elapsed timer would work incorrectly after suspending device during an activity.
  • Fixed an issue where record messages would fail to record periodically and leave gaps in the activity file when the phone was connected.
  • Fixed overlapping timed alerts failing to alert.
  • Restored electronic shifting over-shift tone.
  • Fixed recovery heart rate writing to an incorrect field in an activity file so that Garmin Connect would fail to display it.
  • Fixed consistency of Climb Pro behavior on looped ride.
  • Fixed route recalculation errors after deviating from planned course.
  • Fixed issue where a course with a very slow Virtual Partner could crash the device.
  • Fixed crash when processing Bluetooth data.
  • Added new SRAM gear presets for 13 speed gravel groupsets.
  • Updated Shimano STEPS terminology to "Shimano E-bike".
  • Fixed adding a password protected WiFi network.
  • Fixed Back to Course calculation that requires a u-turn.
  • Fixed layout of graphical data fields.
  • Fix issue where both heart rate and power zones could overlap.
  • Fixed Di2 battery data field to update with proper battery level.
  • Fixed data precision on speed graphs.
  • Fixed ability to delete True Up activities from the device.
  • Fixed issue where the weather widget would have valid data but fail to show it.
  • Fixed layout of map browsing page to show the map scale when a location is selected.
  • Fixed truncation of climb length on climb complete prompt.
  • Fixed some text layout issues.
  • Fixed grade value acting erratic after a suspend/resume cycle.
  • Fixed Stamina Distance to Go units.
  • Updated the icon displayed when the Edge is connected to a computer.
  • Fixed a crash that could occur on power down.
  • Fixed clipping of icons in the Distance to Next data field.
  • Fixed data screens with maps showing the wrong layers.
  • Fixed various bugs and crashes.
Changes made from version 24.18 to 24.19:
  • Fixed memory leak issue that could cause a crash
Changes made from version 21.18 to 24.18:
  • Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
  • Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
  • Added GroupRide awards and climb competitions.
  • Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
  • Added wind and stamina adjustments to Power Guide.
  • Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
  • Added Wi-Fi map download support.
  • Added revamped Course Creator.
  • Updated grade algorithm to be much more responsive.
  • ClimbPro
    • Fixed climb clusters failing to display climb details.
    • Fixed an issue where the climb list page could highlight the incorrect current climb.
    • Fixed climbs drawing on a course when ClimbPro is disabled.
    • Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
  • Added support for India basemap.
  • Added gear presets for SRAM 12 speed cassettes.
  • Added a QR code to quickly pair a Strava account with Garmin Connect.
  • Added search alias support to improve location searching.
  • Added course search to the search bar.
  • Fixed USB connection detection when coming out of suspend mode.
  • Fixed crash that could occur when saving the ride.
  • Fixed incident detection countdown timeout notification priority over any other notifications.
  • Fixed infinite elevation calibration prompt following a manual calibration.
  • Removed tone from elevation calibration prompt.
  • Fixed mute toggle interactions on the notifications widget.
  • Fixed pausing navigation.
  • Improved speed of city search.
  • Improved phonetic and hand-writing keyboard input.
  • Fixed ride button failing to show after receiving and reviewing a Connected POI.
  • Fixed friendly name for phone pairing.
  • Fixed issue where hazards in China could appear offset on the map.
  • Set minimum backlight level to retain screen visibility after backlight timeout expires.
  • Persisted backlight level setting through battery saver enable and disable.
  • Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
  • Fixed display of battery level when it dropped below 5%.
  • Fixed small roads on map being drawn too thick.
  • Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
  • Fixed an issue where British coordinates could not fully be entered with the keyboard.
  • Improved layout of post-ride highlights page.
  • Fixed various crashes and freezes.
Changes made from version 21.17 to 21.18:
  • Fixed potential crash and lap data loss when turning the device off mid-ride
Changes made from version 21.16 to 21.17:
  • Fixed connection issues with BLE sensors that do not support secure connections
Changes made from version 20.19 to 21.16:
  • Added support for button control and trim adjustments for SRAM AXS shifting systems
  • Added the ability to send and share locations from Apple Maps
  • Fixed glance refresh issues on the main page
  • Added lap ascent and descent data fields
  • Fixed solar graph display on post-ride highlights page
  • Fixed courses with special characters not loading properly
  • Fixed connectivity of Polar Verity Sense
  • Fixed an issue with GroupRide course downloads
  • Fixed issue where lock on road setting was not being honored
  • Fixed issue where true-up activities could not be deleted
  • Fixed frequent disconnect issues with 2M PHY connections
  • Fixed an issue causing excessive battery drain during suspend
  • Fixed an issue with real-time settings data screen layout editing
  • Fixed partial display update issues with suspend mode
  • Fixed issue where BLE sensors would not connect
  • Fixed potential issue where segments on the filesystem were not drawn on the map
  • Fixed audio prompts for speed
  • Fixed issue with elevation calibration prompt appearing repeatedly
  • Fixed off-segment tone issues
  • Fixed VO2 display on four-week history graph
  • Improved default connection interval for BLE peripherals connected via Connect IQ apps
  • Fixed issue causing translations to be removed
  • Fixed crash when importing large GPX files
  • Fixed road lines being drawn with the wrong style
  • Fixed issue where auto brightness would stop working
  • Fixed crash when drawing the alpha mask for CiQ icons
  • Fixed hourly wind speed display
  • Fixed workout comparison graph in ride history
  • Fixed gear battery data field for certain ANT sensors
  • Fixed CiQ data fields with developer data not appearing correctly
  • Fixed issue displaying courses on certain maps
  • Fixed positioning issues near Chinese borders
  • Fixed searching issues with Japanese keyboard
