After updating to the latest version (v25.25), my Edge 540 is taking a few minutes to acquire GPS signal. The first couple times this happened I "fixed" it by rebooting the device a couple times because I wasn't sure which was causing the issue. But after checking the map once an activity has been started I can see the message "Acquiring Satellites" (although I can see 4/5 or 5/5 signal intensity). After a few minutes it shows "elevation calibrated to location" and the Edge starts tracking speed and distance as it should.
It doesn't sound terrible waiting for 2-3 minutes after starting an activity but as I mentioned this is something that never happened before, and I've been using this Garmin for more than a year now. I've been always using Auto Select for Satellite Systems option.
Has anyone experienced something similar?
