Backlight disrupts temperature reading
Exactly same issue as with 1040 in this topic https://forums.garmin.com/sports-fitness/cycling/f/edge-1040-series/397551/the-backlight-disrupts-the-temperature-reading
It also occurs on my 540 Solar, exactly the same - depending on backlight intensity, the temperature error can be as from 1 to 5 deg.C, When auto-backlight is On, you can't actually know how much the error is in current reading, this is quite annoying.
Since we run both 1040 and 540 (my wife's) we noticed the temperature readings are different on these 2 units while we ride together - obviously because we use different backlight settings (one unit is on auto-backlight, another one has auto-backlight off).
 you were asking about use-case for temperature, so I can explain here since you closed the original topic for investigation.
First, for trainings the temperature balance of one's body is essentiall, neither you should overheat or chill too much. During long rides knowing exact outside temperature is key, so that you can judge whether you should put up some additional layers of clothing, or remove. Especially if temp changes more than 5-7 degrees during a ride. Especially around freezing point - then you'd also watch out for black ice. My several rides this year were in mountains -  starting from +28 deg.C on the coast, and going to +10 deg.C on top, so I knew I absolutely should not stop there for long but either go hard to generate a lot of heat, or turn back and descent immediately, despite my spare jacket in the bag. At +10 C I need to act differently compared to (if it was) +15 which I could have standed for long time no any issues. So you see 5 C error quite matters.
Pulling out your smartphone to check temperature online is not an option on the ride.
I've got another IQ datafield for temperature - Windfield, it shows temp at nearest weather station, but it can differ a lot due in coastal / forestal locations, I mean really a lot. So it's not that realiable. Another issue with weatherstation temperature - it shows just air temperature, but no sun-heat effect. While Garmin body does heat up in the sun and this is much more relevant to what your body feels under sunheat.
I guess this explains why Edge built-in temperature sensor reading is essential for those people who do training sessions, or long rides.
Please could you look at it and fix it, it seems to be a common issue for Edge devices.
For the record, both my 540 and 1040 are running latest software,25.24. I couldn't say if the problem were there with earlier software, because I didn't recognins that temperature reading irregularities were connected to baclkight so I didn't test it then.
Thank you!
  • Hey! Could you provide a video displaying temperature data field changes with backlight use on your 540?
    I appreciate the context given here. Comparing different types of temperature measurements and their changes is tricky due to the external factors you mentioned. I will let you know when I have more info.
  • I may have time later during weekend, but it looks the same as with 1040.
  • No rush - Anecdotally, I can see this myself for Edge 1040 but not reliably with Edge 540, and evidence displaying this behavior helps our investigations greatly.
  • Here are videos of 540, I was able to reproduce 2.8 C error compared 10% and 100% brightness.
    Since with higher brightness the temperature reading goes down, I guess it's caused by voltage drop.
    1 -  https://drive.google.com/file/d/1GOpkUZwlz6aAGo_27GF1qHazRS2AFqQ1/view?usp=sharing
    2 - https://drive.google.com/file/d/1ItYbKawr1b_UabDgrQtVxZCWntp-vCNQ/view?usp=sharing
    Key in this test is that you don't hold 540 by hand, because it will heat it up additionally.
    Hope it helps Garmin to fix this bug.
  • Can't believe in what i'm seeing, I'm with the exactly same issue, it's so frustrating, two days ago I know the temperature was about 14ºC and Garmin was measuring 18ºC for hours!!!!
    I'ts makes no sense to temperature increase when brightness reduces it must be the opposite
  • The device may display temperature readings that are higher than the actual air temperature if the device is placed in direct sunlight, held in your hand, or is charging with an external battery pack. Also, the device will take some time to adjust to significant changes in temperature. (Edge 540 Manual: Temperature Readings)
    Because the Edge thermometer is subject  to external heat, you will see differences between it and ambient air temps or weather data. We are continuing to investigate the screen brightness resulting in noticeable changes to the device temperature data.
  • Never had  temperature problems with the edge 530, that's why I'm disappointed
  • This is insane. Great find!
    I repeated this on my EDGE 840. Relatively accurate readings with light low or off, but when I increase the backlight to max, the temperature reading drops a couple degrees C.
    Leaving it on max brightness to settle, then switching backlight off, it overshoot's the original temperature it showed when the light was off by another couple degrees C.
    ie, I boot the device with my default light off or very low light. Temp shows 24.5ºC. I leave it for a minute to settle. ( its been stored next to my indoor thermometer which shows 24.4ºC)
    I then increase backlight to max, and leave it for 5 min. It settles at 22.9ºC.
    I then bring it back down to min brightness for 5 min, and it settles at 26.4ºC
