Suggestion: Option to Disable Map Display During ClimbPro
Dear Garmin Team,
I own a Garmin Edge 540 series. When I’m cycling and start a ClimbPro ascent, half of the screen displays the map. Would it be possible in future updates to add an option to disable this map? The climb data is simply unreadable in this mode. Too small.
However, when I’m following a route, this map doesn’t appear, and the data is then perfectly visible.
Thank you in advance for considering this suggestion, and for your continued work in improving your devices.
Léo
