Unable to remove courses
It's impossible to remove a course from my Edge 540 Solar.
When i browse to Navigation>Courses and press the three dotts, there is no option to remove the selected course.
Does anyone have a solution? If not, please Garmin, fix this bug. My list of courses is growing and growing, it takes several minutes to search for the correct course Disappointed
  • On my 530 you select the course and there are then 6 options, only first 3 display, scroll down (using down arrow key) to the 6th one which is DELETE? Don't have a 540 so don't know if the same?
  • Hi, thanks for your answer. But on my device the delete option is not there. But I solved it. On the main screen (courses) there is an option to remove courses, so my problem is solved
