Hi all,
I've a fenix 6 and I've recently bought an Edge 540, so I've started to track cycling activities using Edge instead of fenix.
The Edge is configured as "primary Training device" and the fenix is the "primary wearable device". First question: I haven't found a way to change the training device priority either on Garmin Connect or on the web portal: the devices are set that way and I can't change it. Perhaps this feature was removed recently ?
My Training Status seems to be correctly aligned on Garmin Connect app but the fenix device ignores Edge activities and the training status is always "Detraining" on the fenix.
Phisyo True Up is enabled on both devices. The software of the devices is updated to the latest released version (Edge 20.19 and Fenix 22.10). I tried removing and adding both devices from Connect but the behavior is still the same.
I expected the training status to be shared between the various devices and to have a unique situation on both. I read that these devices should support Unified Training Status.
Did I miss something?
