Firmware version 20.19 for the Edge 540 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
100% as of 3/14/2024
Changes made from version 19.22 to 20.19:
- Added NavIC support.
- Added keyboard suggestions to the location search feature.
- Fixed crash in extended display mode when executing a workout.
- Fixed writing free climb category so that it displays in Garmin Connect.
- Fixed crash for long distance rides.
- Fixed POI search for conflicts in the map data.
- Fixed auto pause resetting smart trainer resistance during workouts.
- Fixed light network battery status icons for components with an external power source.
- Hid disconnected radar icon when in an indoor activity profile.
- Fixed issue with pairing multiple BLE sensors.
- Fixed crash when connecting to RCT715.
- Fixed live segments updating during activities.
- Fixed the resume navigation feature after diverging from a course.
- Fixed truncation of creation date for courses in the dynamic glance area.
- Fixed refresh of mobile notifications page.
- Fixed ClimbPro behavior on bridges and through tunnels.
- Fixed ClimbPro climb detection on branches with loops.
- Clarified whether the source of an automatically detected maximum heart rate was from directly measured values or estimated from the user's activity history.
- Fixed elevation plot overlap with map while zooming.
- Fixed displaying emojis in startup.txt file.
- Fixed other minor issues and improved device stability.
Changes made from version 19.19 to 19.22:
- Fixed auto backlight issue causing battery drain.
- Fixed BaseCamp compatibility.
- Various Bug Fixes
Changes made from version 18.25 to 19.19:
- GroupRide
- Improved GroupRide scheduled ride time picker.
- Fixed GroupRide keyboard showing non-English keys.
- ClimbPro
- Added shortcut to ClimbPro screen by tapping the "Climb!" prompt.
- Added estimated time to end of climb for Time To Destination data field during a course ClimbPro climb.
- Fixed elevation page and ClimbPro for indoor trainer course use.
- Fixed invalid climb split cadence values.
- Enabled manual setting of Resting Heart Rate to enable Fitness Age calculations on Garmin Connect.
- Added smart notification images for apps that support them.
- Enabled workout auto pause when activity profile timer auto pause is enabled.
- Added button support to elevation data screen for axis scaling.
- Updated VO2 Max page to show four weeks of history at a higher resolution.
- Added prompt to make it more difficult to accidentally discard ride.
- Increased touch area for music controls data page.
- Fixed auto scroll timer loop and menu indicator interaction.
- Fixed CIQ alerts crash.
- Fixed Korean keyboard translation.
- Updated Twitter references and icons to X.
- Fixed Di2 shifter ordering in battery data field.
- Fixed syncing auto detected FTP and lactate threshold heart rate to Garmin Connect.
- Fixed front gear data field for Classified Powershift gear hub.
