My heart rate, occasionally, appears to rise way above normal levels for short periods, at the same time the calculated respiration rate appears to pause. Not sure if I can add a screenshot which shows it clearly. Hb rises from 145 to 206 in 2min fault?
  • I'd imagine that is a problem with your HR monitor rather than the 530. Respiration data is calculated from HR data so any issue with the HR is likely to cause an issue with respiration data.
