I recorded a ride on my Edge device today. It shows up in the history, but it won't open (other rides will). It won't upload. How do I get the ride to upload?
Thanks,
bc
Thanks,
bc
Try a manual upload from your Garmin device to Garmin Connect Web - How Do I Manually Upload an Activity I Recorded to Garmin Connect?
If you get any message other than Import Complete, then there is a problem…
If you get any message other than Import Complete, then there is a problem with the file. Attach it to this thread. We can take a look to see if it is repairable.
The manual upload failed.
Here's a compressed file. After looking at the file size (1k compressed), I suspect there's no actual data there. It was a 3 hour ride, so I would expect significant file size. Any idea why this happened?
Thanks,
bc
Only 2 timestamps
For what it's worth - 2025-02-16-10-17-33-fixed.fit
Hard to say why.
The recording ended abruptly and without the expected summary records. Probably data records at the end of the recording are missing.
Typical maintenance to minimize a reoccurrence would be to delete all activity history from the device - Removing Activity Files to Free Up Space on a Garmin Device | Edge® 520 | Garmin Customer Support
