Calibrating Tacx Flow via Edge 530 – target speed doesn't show up
I've tried and failed multiple times to calibrate my Tacx Flow using the Tacx Training App – when the calibration does complete it is always "too loose", and twice I've adjusted the dial too far and the bolt has fallen out. (I have a new trainer tyre installed, I've warmed it up but still nothing.)
I've seen forum posts that say that the Flow can be calibrated using an Edge 530. So I've tried that too – but I get to the "Pedal to Target Speed" screen and no target speed ever appears. Is there something I'm doing wrong?? I've set the wheel size and gear ratio manually, but that didn't help.
(Running software version 9.75 on the Edge 530. FWIW, the Flow seems to respond correctly to the course whenever I've ridden on it.)
