I'm using Edge 530 on my track (bike) rides, and noticed on my last ride that near the end of the ride, the speed indication (which is supposed to be picked up by the ANT+ wheel-sensor) started to show lower speeds that what it should have showed. While our riding speed kept around 40km/h, the indicated speed slowly dropped down to 35 and further to around 30km/h. Initially, I thought it was just me getting tired, but the readings from my cadence sensor stayed normal and stable (we use fixed gear on track...), proving that my speed certainly didn't go down that much. What could be the reason? I did check that the sensor was still well connected the to wheel axis, so I doubt that it is slipping on the axis (but hard to prove). I might try to fix it a little more snug next time. Stillneed to check the battery status of the wheel sensor, that might be another reason. Any other things that could result into this bahavior?
