My Garmin 530 ride info will not show up in Garmin Connect Calender. However, it does show up in the Garmin Connect activities. Any suggestions? I would like the calendar to reflect my rides from the Garmin 530. Thanks
Calendar view, top right, three dots, "Filter Calendar"; make sure "Activities" is checked. Also in "View Compatible Devices" see if 530 is listed, it should be. If not, I don't know how to fix, but someone else here likely will.
Thank you. On my desktop cycling was unchecked in the Filter. I appreciate your help. Cheers
Excellent, glad it worked out!
