Hi all.
Had a search and couldn't see anything exactly like my problem.
Have an Edge 530 which has worked perfectly for 4 bikes since day one.
The last two rides, it has got the distance covered wrong by around a factor of 3 (too low)
The map plots ok in Garmin Connect and it uploads to Strava but, I need to use Strava to correct the distance - which it does.
I wonder what Strava uses to calculate distance - is it something in the file or from the map - either way there is something in there that is corret, it just doesn't display as such without user intervention in Strava. Distance still wrong in Garmin Connect app of course.
Anybody had anything similar?
