FTP test wrong initial Power, not working
Hi all, I've tried them all but I can't get the Garmin FTP test to work, neither on Edge nor on fenix, same behavior. Let me explain.
I have an FTP set to 265w and the zones correctly set with minimum at 0. In my records there is maximum power at 20 minutes 279w. The values are identical on the GC and in the device menus. The test starts at 180w and finishes the last step at 280 and then tells me it failed to verify FTP. Based on my readings, it should start much higher. I have tried to vary the FTP by hand by entering 100w, 600w... but the test remains identical!
I should add that I weigh 69kg and have vomax 49.
Does anyone have any ideas?
Thanks in advance!
