Fixing the standard bracket with rubber rings
Hello all,
I have a Garmin Edge 530. With the device are two standard mounts that are tightened with rubber rings.
In my opinion, the rubbers are very short. With the longer ones, the holder can be attached to the handlebars. But the stem is much thicker. Since I do not get around, or am afraid that the ring does not withstand a stronger pulling. That's with my Treckingbike so and with my MTB the stem is even thicker.
How is that with you? Does anyone have a solution? I would like to buy there no additional brackets.
Greetings Christian
