I have uploaded a route to my Garmin Edge 530 unit and started following it, but the route on the Garmin display is not accurate to the actual ground conditions. For example in a test ride I am following the road that the route should also follow (I know since I made the route and am local to the area), but on the display the route seems to be offset by 50 - 100m from the road I am on which is the actual route. As such the Garmin is constantly stating I am off course when in fact I am not. I have double checked against another GPS (my Gaia on my phone which has the exact same route uploaded to it) and it is showing and following the route accurately. I am going to double check against another friends Garmin 530 unit to see if it something to do with this particular Garmin unit. This is very concerning and annoying as I will be relying on this Garmin 530 unit to navigate myself on a long distance bike ride shortly and need it to follow the route accurately in places where I don't know the route. I have turned off Route Re-calculate Mode. I have tried both GPS only and also GPS plus GLONASS and this doesn't make any difference. I have calibrated the compass and this also has not made any difference.
Can anyone help or have experience with this?
Thanks Lucy
