Edge 530 not up reflected in Training Load (rides visible in Connect)
Hi everyone,
Having issues with my Epix2+Edge+HR strap setup. Bought Edge 530 in Jan and used it only indoor with smart trainer - that worked fine, all was uploaded and reflected in single raining load using Physio True Up.
Since I started to ride outdoors I am having issues - the Edge recorded activities show up in Connect, show activity load on activity details page - but doesn't update the overall Training Load in Connect!
So far Garmin advised:
- sync Edge before activity start to make sure it takes current data (tried, no change)
- start few seconds activity after the main one and discard it (tried, no effect)
Obviously when I record with Epix and HR strap it works.
Any advise?
Thanks
    0 Former Member over 1 year ago
    [deleted]
  • Hi, yes smart trainer has power meter which I do not have on my bike. But the setup has not change other then that - i had both and used Edge to record. That should not make a difference to record TL though, right?
    Epix is showing same data like Connect - so same TL, and even showing the activity in "last activity" synced from Edge.
    Physio True up is enabled on the Edge (it's on by default on Epix and can't be turned off). I even tried to re-enable it...
  • To illustrate better:
    3 activities recorded with Edge 530, TL 544 (after activities are uploaded, same as before they were uploaded - no effect)
    Once I upload same activity (just recorded as one activity instead of 3), TL is 728.
    What's the point of recording activity on the Edge? I just don't get it...
