i'm facing an annoying issue. by garmin 530 my ride is saved as e-bike ride and i have to change it into e-mtb ride.
someone solved this? How set e-mtb by default?
thanks
thanks
I've checked. The issue isn't there. My setting is E-mtb. So the issue is inside strava or inside the how garmin comunicates with strava.
what i'v discovered is that if i don't connect to my levo sl the garming saves the ride as emtb, if i connect to the levo sl the ride is saved as ebike. something with the sensors connected..i supposed…
Check the ride type setting under the profile you are using
Menu - Settings - Activity Profile - name of profile to change - Default Ride Type
thanks for your answer. where do you refer? on 530, app garmin or app strava= via browser?
Sorry I misunderstood the question. I thought it was incorrectly setting the activity to -e-mtb in Strava, when the problem is the opposite.
