I searched and did not find it.
Is there any way to not show map or routing AT ALL for an outside activity?
I load a route only to have the ETA and distance remaining, but I don't want anything from the guidance.
Thanks for your help.
Map display can’t be switched off.
Turn Guidance On/Off is located under Menu>Navigation>Courses>Course Options.
Course Points On/Off option is available under Course Settings once a course is loaded.
However, if Course Points are off the ETA fields etc. for intermediate points will be also be blank, although it might be OK for the finish point.
