No GPS at Ride Start
Issue on the last two rides, no issues previously, latest firmware.
I'm in Flagstaff, done dozens of rides from the same start points with no problems previously. Last two rides, all sensors connect fine, all looks good. But "Locating Satellites" prompt keeps coming up. When I look on the status page, no GPS signal. Open sky areas, no clouds. It won't connect until I disable GPS, then re-enable it, and select GPS + Galileo (Glonass might work to, haven't tried it). After I do this, it connects with a full strength signal, and stays that way with no issues until the ride is over.
