The map files have .img extensions.
gmaptz.img is the timezone map and should be left alone.
gmapdem.img is the elevation map.
The ones with the biggest file sizes will be the road maps. You could always move one of them off at a time and then look at the map list on your unit to see if a map disappeared. If you keep them safely stored on a computer you can always put them back at any time.
