I just installed the sram power meter crank upgrade. The sram ax’s app sees the sensor, but my edge 530 won’t add the sensor. On 9.4, any ideas? Please
8438523 when you try to add your power meter, does the Edge find the sensor? I'd recommend going into the Menu > Settings > Sensors > Add Sensor > Search All and wake up your power meter to see.
If the sensor is found, go down and select it, then go back and select 'Add Sensor' to add it to your 530.
