My new Edge 530 recognises my (ANT) Stages 22066 Power meter but when I try to Add it, nothing happens. I've downloaded the new version of the Stages App which has connected with my smartphone. So what do I need to do next?
1970971 What button process are you going through on your Edge when you try to pair your Power Meter?
If you search for the power meter, and then it is found, you should be able to select the checkmark in the box next to the power meter name, then scroll and select OK on the Add option. Are you not seeing this?
My reply has vanished? Yes, I've done all that but the Edge does not save my selection.
