Hello, I have a Europe based 530 with last map update n. 2021.20
I often find new routes not covered, is there anybody who knows if and when Garmin will finally update maps?
Thanks
In the meantime you can use the free OSM maps from www.openfietsmap.nl, https://extract.bbbike.org (use the latin-1 taste), etc. I do not own an Edge 530, so I cannot give you details for the installation. For other Edges placing the map image file (example: abcd.img) in the folder ..\Garmin is the standard procedure. Be aware not to overwirite existing gmapsupp.img files by renaming the downloaded map file to something meaningful, for example OFM-BNL.img
