Hello,
My Unit Starts with an Unusual Menu:
Burn-in Test
BI test Check Sum
General Information
Memory Test
Key Press
Display Evaluation
Beep
ANT Sensors
What is happening ???
appreciate any help!!!!
Hello,
Burn-in Test
BI test Check Sum
General Information
Memory Test
Key Press
Display Evaluation
Beep
ANT Sensors
On some past units I think the Start button being held or pressed when the unit is powered on caused a Factory Test mode to be run. I don't have my device on me to check this for the 530, but I would also suggest turning it off, checking that no buttons are pressed or stuck and then turning it back on.
Have you been able to fix this? I have the exact same issue
Hello Rob,
No fix was found! Garmin replaced my Unit under warranty!
Perfect service :)
Antonio
Thanks for the info! I’ll contact Garmin and hope I’ll get the same service then :-)
