Hi everyone,
I'd like to customize the data field layout in a way that it looks like this:
I do want to see heart rate, power and speed as graphic fields also showing max and average.
And additionally add distance and timer
The problem is the preset for 5 data fields only allows this layout:
As you can see the graphic displays of heart rate, power and speed now do not show the full information including max and average.
For example, if in 5-B the second field would be smaller then the first and last a little bit larger I wouldn't even mind the position of the data fields I'd like to see, but i can't get it to work.
I even tried to choose a data field layout with more fields i need and manually erase those i don't need, hoping it'll result in the one I've shown.
But whenever erasing a field the remaining number of fields will always preselect the x-A scheme of that selected number of data fields...
Any ideas how i could get that to work?
