I've used the Start and Lap feature and it works absolutely fine. The problems start when i start my ride on the edge at home and then try to use Mark and lap when I arrive at the start of my loop circuit. I have the auto lap set at Mark and Lap and as i approach the top of the loop I press the lap button. This is immediately followed by a left turn onto a straight and a few seconds into the straight, the edge clocks up a lap of several seconds and commences Lap 2 as though there is a marker set in place already. Each time I pass the start of the loop I get 2 laps clocked up: one real lap and a silly 6 second lap. This has happened twice now and only goes away when I use start and lap instead. There are no saved locations and no visible map markers in this location.
Could it be that the edge is remembering earlier start points ? Has anyone else had this problem ?
Cheers
Dave
