I'm on version 8.20
My time is not synced even after GPS is locked.
It also does not have the ability to set time when GPS is unavailble as fixed on version 5.24.
Any advice on this?
If your Edge is paired with your mobile phone in Garmin Mobile Connect app then it will sync this timezone map file with next sync. (But probably it will sync it via wifi connection too if the BT pairing is not done). On your computer there is the Garmin Express app, so if You connect it with USB cable, then the Express will sync this timezone file too. It must work, check in file manager again that is there new gmaptz file in the folder and what its date (should be the today's date)
