This is very weird, because it happens on all sensors
- Heart Rate (Garmin Tri)
- Shimano Di2
- Power Sensor (Vector 3 left side only)
First time I noticed was the heart rate, and I believed it was a battery problem on the sensor, so I replaced it, but the previous battery was at 3.2v, so lot of juice!
the problem continue to happen and then today the Di2 sensor was dropping probably about 80 times on 4 hours ride.
It's concerning because it's clearly not a sensor issue as different sensors are presenting the issue.
This started to happen about a month ago.
Today I installed the beta firmware 8.13 but there is nothing on the changelog about this issue.
I see many people reporting similar issues, but no solution at all.
Any recommendation ?
Thanks
