I require speed from the rear hub when I warm up for time trial stages. It's never easy to switch this over on my 520; but, it does work. I discovered that you receive one or two blips of speed with the 530, otherwise it's a total fail. I purchased a new dual-band speed sensor and it too was a fail. I'm at a loss to explain why the sensor works on the older model 520 and the 530 lacks the sophistication to pick it up. Any thoughts as to a possible resolution?
