New Edge 530 Public Beta 7.23 Now Available
A new Beta software for the Edge 530 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 530: https://www8.garmin.com/support/agree.jsp?id=14953
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 7.19 to 7.23:
  • Fixed various issues with course routing.
  • Fixed issues with indoor course mode.
  • Fixed issue with blank Strava segments appearing on the Segment Explore widget.
  • Fixed Browse Map panning.
  • CIQ
    Improved CIQ data field settings experience by always prompting when adding a settings-capable CIQ data field.
    Increased font size for app background messages.
Changes made from version 7.10 to 7.19:
  • Course Routing
    Improved course routing speed.
    Added automatic course route caching.
  • Map
    Improved map visibility and contrast with new map themes.
    Added a popularity layer to highlight roads that Garmin users have ridden the most.
    Added directional arrows to routes, courses, and history lines.
  • Phone
    Added smart syncing before an activity.
    Added a Sync Now button to the settings widget and the Connected Features > Phone menu.
  • Updated Firstbeat library for various improvements and bug fixes including a fix for training stats being reset on a multiple day activity.
  • CIQ
    Fixed issue with BLE sensors in CIQ data fields after waking the Edge from sleep mode.
    Fixed issue where activity controls would not work in a CIQ app.
    Fixed other minor issues.
  • Fixed several inReach issues.
  • Improved Garmin dual-mode sensor management.
  • Improved power meter calibration and software updates.
  • Improved the cycling dynamics page.
  • Increased maximum number of workout steps from 50 to 100.
  • Combined the indoor trainer Target Power and Resistance data fields into a single new 'Trainer Mode Value' data field that will dynamically change the title and value based on the current trainer mode between Target Power, Slope, and Resistance options.
  • Added support for including metabolic calories in the total calories reported in the calories data field and recorded in the activity file.
  • Fixed manual elevation calibration.
  • Fixed minor bugs.
  • Improved device stability.
Installation Instructions
  1. Connect your Edge 530 device to your computer using the micro-USB cable.
  2. Download and unzip Edge530_723Beta.zip folder.
  3. Copy the GUPDATE.GCD file from the Edge530_*** distribution folder to the \Garmin folder of your device's internal storage drive.
  4. If there is a GPS_*** folder, place the 006B310706.GCD file into the \Garmin\RemoteSW folder of the device. Please note, not all Beta releases will include an update.
  5. Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
  6. If you would like to revert to the last public release software, follow the above steps but place the GUPDATE_710.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
  • tested today... One disconnect, but everything got disconnected: HR, Quarq, Speed, Varia. All at once. Self-reconnected couple of seconds later.
  • What about biggest fonts ? Bigger screen of 530 is useless with smallest fonts than 520 !
    Datafield fonts are too small !!!
  • So for some reason they're not getting rid of Virtual Partner.   I think all the navigation stuff seems to be great.
    Something I don't fully understand . . . . So - if you're navigating a course and wearing headphones and have your phone - the 530 will communicate with the phone - and then you get turn by turn in your ears.
    I have a Varia  - why won't my garmin communicate with my phone and then alert me to cars in my headphones?
  • I suspect as new Varia can do this with its own phone app this is never going to happen.  The frequency of the beeper on the 530 is almost impossible for me to hear when riding so I'd really like this too (and am not going to spend £170 on a new unit)
  • Yep - the new one can.  But this is easy to do on the old one . . . Just like the 530’s turn by turn - which is controlled from the connect app. Typical
  • I agree with you 100% - I was surprised that it wasn't there when it came out and even more surprised it's never been added.   The Varia is sold as a safety device but does not address with hearing issues.
  • Sorry Garmin, this is not an "improvement", started trying 7.23 today and I don't wish to harp on about the direction arrows but they are gross and there is still no option switch to turn them off, if this is the case in the final version I will not be upgrading nor I expect a lot of people in my club. We do a lot of long distance, multi-day / night / multi-night rides and a clear uncluttered map is a priority. Not only do the arrows get in the way of viewing the route line / junctions etc but if the route is an out & back then you get arrows going in both directions. Please a switch so the MTBers who seem to like these can have them and those that don't can turn them off. Noting the Indoor Course mode issue seems fixed, Thanks,
                   *High Vis" Theme)                                           "Classic" Theme
  • mas alguem teve problema na hora de transferir o percurso criado no PC para o GPS e triplicar  o valor da altimetria?
    exemplo: criei um percurso de 100 km com 2000 de altimetria e ao sincronizar ao gps 530, a altimetria saltou para 5000. liguei para o SAC e falaram que nao sabem a solução, mas estao cientes do caso. patifaria isso, gastar caro num equipamento e ter este tipo de problema.
  • I'm spamming everywhere I can, begging You Garmin devs and whoever is responsible.
    If you don't want to lose riders to wahoo, work on the garmin app to let us make changes for the egde via phone, like the wahoo can do.
    Changing settings on the 530 is so tedious. I get that you wan't me to buy the more expensive model with touchscreen, but this is just cruel.
  • You are a bit slow or your colleagues are bad at inforrming you:
    ”Changes made from version 7.23 to 7.24:
    • Fixed an issue with calculating course routes on 3rd party maps.”
