edge 530 does not record FTP since last Summer.
I use the same bike with same hr-sensor and same powermeter as before.
The last recorded data is from August 2020.
The vo2max though has been recorded correctky until today.
Any ideas?
Any ideas?
FTP & Vo2max require you to be working at least 70% of your heart rate, check settings for Heart rate & power zones in your profile also your body weight, you can also do this in the online profile
Cycling VO2 Max Estimate
go into your garmin profile Menu->My Stats->Training Status and then scroll down until the FTP box is highlighted then press enter, then set enable auto calculation. Vo2max & FTP are closely related if you did a 20 min test the vo2max=((FTPWatts*10.8)/YourWeightKg) +20+1
It also calculates the Lactate Threshold HR
if you scroll further down Performance Notifications has the New Vo2Max
Scroll further to Training Zones and in Heart Rate Zones you can set Max HR and Lactate Threshold HR and then can be set on auto calculate, Resting HR should be your HR after waking up in the morning.
online user interactive manual to do FTP test www8.garmin.com/.../GUID-4A55785E-248E-46DF-8BDA-7CC563477E6D.html
